- Claflin
- KS
I am looking into another 4.0/AW4 drivetrain swap from a '93 Jeep Cherokee XJ, this time into one of my CJ7's. The Jeep this is drivetrain will be replacing has a 4.2 with the TF999 auto. The Jeep currently has a B&M floor mounted ratchet shifter, which I would like to replace with an original CJ auto steering column (shifter mounted on column) I already have so my wife can drive it (she has a hard time getting the floor mounted ratchet shifter into gear). Has anyone ever swapped the AW4 transmission over and used the OEM CJ automatic steering column to select the gears? There is the same number of shifter positions (P,R,N,OD,3,2-1) with the AW4 as the original auto equipped CJ's (P,R,N,D,2,1) since 1st and 2nd gears are in the same shift location on the AW4 so the one major variable I can think of is the length of throw each transmission requires between each gear. Ideally, I would like to do away with the original TF999 linkage and use some sort of cable shifter to eliminate any binding. Has anyone come across any combination of parts that will allow this to work?
