- Rockville
- VA
I'd post this on the JU board, but it's been out for days.
My son's 2000 Grand Cherokee with the 4.7 V-8. This started as an intermittant issue. Turn the key and nothing but a quiet click, not the starter solinoid. Checking it over, the starter solinoid was very hot...so I figure it's bad. Today, I put on a new starter (good one from NAPA)....still the same
. I checked the relays (should have looked here first, probably), swappped the wiper relay for the starter relay (same numbers on them), still the same
. Looked for and tightened grounds I could find, might not be finding them all...nothing
. The battery voltage seems low at 12.10 to 12.47, with little change when you turn the key.
Need some help here, what next??
My son keeps taking my vehicles...not good.
. The battery voltage seems low at 12.10 to 12.47, with little change when you turn the key. Need some help here, what next??
