OT: pellet/wood/corn stoves
In Alaska, I kept the deep cycle battery from my boat charged with a inverter hookedup. Used it once in two winters.
Power goes out, plug into inverter and away you go.
I was thinking a small bank of deep cycles, power invertor and a solar panel would be a good thing to have....
Corn is currently at near record highs. Over $260/ton. The price of corn has been steadily increasing since around 2005 due to ethanol production. If I were looking at saving money I don't think a corn stove would be top of my list right now.
I thought that corn Pellets were the left over By Products of growing and use. So shouldn't they actually be cheaper if there is so much being grown and used for the production of Ethanol??
Or are Corn Pellets using everything from the kernel?
Just interested to know.
Also would it be good to keep the pellets in the same room so that you can use the heat from the stove to help keep them dry and add that humidity from them to the room in the dry winter?
Carl
Carl
I think you're confused. There are pellet stoves, which burn compressed wood pellets made from sawdust or wood chips, and there are corn stoves which burn whole kernel corn. You can indeed buy corn pellets, mostly as animal feed, which are made from compressed corn gluten and burn these in a pellet stove. A pellet stove will burn any compressed biomass pellet, it doesn't care what the source of the biomass was. But a corn stove is designed to burn whole kernel shelled corn.
I did not know that. We have a lot of the Pellet stoves on the East Coast and I figured that in the mid west they just took the left over stuff from a corn harvest and pelletized it. Kind of like what they do to make wood pellets.
Seems a shame to grow all of that corn and then burn it.
But I guess that you learn something new every day.
Carl
My thoughts
I put in a pellet stove 2 years ago and it cut my winter heat bill in half. 1200 sf house and I burn about 2.5 tons per heating season.
My advice about pelllets- try different manufactures available in your area to find out which ones are best as I have found that there's a big diference in btu output between them. The best ones I have found are usually made in Kentucky or Tennessee. Some are just crap. When you find the best ones, go ahead and buy a whole seasons supply because as the winter goes on, the venders may run out or they get them from whoever they can and they may not be the best quality.
Greg
Just an update for you guys:
If your going to install a pellet/Corn furnace of any type. be sure to check your your insurance coverage.
Alot of policy's being written lartely have clauses about non-utility based heating. ie space heaters, both oil and electric, and pellet/corn stoves.
Aparently this is something that has just come up in the last few years, and I just found out about it..
hope that helps some you guys.
A couple years ago I fixed broken clay flue tiles in a wood burning fireplace by installing a cheap wood burning insert and a stainless steel insulated flue liner.
This wood stove/insert forum was invaluable in learning how to do it: http://www.hearth.com/econtent/index.php/forums/viewforum/2/
They also have a pellet and multifuel stove forum: http://www.hearth.com/econtent/index.php/forums/viewforum/22/
FWIW, our cheapo ($600) small wood burning stove/insert + $300 25' SS insulated linear installed DIY would be plenty fine for basement heating if you only occassionally needed heat. During the dead of winter, small wood buring inserts/stoves will reasonably provide about 4-6 hours of heat without attending to it. However it won't be a constant room temp that your accustomed to with a regular furnance.
For our purpose though (ambiance and supplemental heat) it is a perfect low cost solution to fixing the broken flue and getting the fireplace operational.
As for indoor storage of seasoned fuel, we have it but I would not risk storing seasoned wood indoors that has been "seasoning" for 12-18 months outdoors. Why? too much chance that you'll bring carpenter ants into your home. Our wood seasons in a rack 100' feet from our home near a treeline.
Only after the weather falls to an average of 32*, do I bring it closer to the house under a tarp. When we need wood I'll bring in only enough to use at that very moment. I'm kicking around the idea of finding a way to "seal" wood indoors for the initial fire (e.g., large heavy duty plastic bag, plastic barrel, etc.), but haven't stumbled upon a good cheap/free solution yet.
