OT(sorta) - CJ7 Driveshaft question
RubberDuck
Baltimore
MD
Hey guys. Just picked up a super-straight 79 CJ-7 Renegade as my woods toy, and am scratching my head on something. The PO was in the process of converting from auto to manual and swapped in a T-15 / Dana 20 combo with a new bellhousing on a 6cyl engine. It appears the rear drive shaft would need to be about 29" with the front being 28 or so. I found a driveshaft for the front, but the rear seems to be an "off" size unless I'm missing something? This combo not being stock, I'm not sure what my options are?
If you call Tom Woods or any other custom drive shaft maker, they'll just make up what you need. It's not as cheap as used parts, but it isn't too bad for a basic shaft.
With the t15 only comming in the CJ5 and CJ6 304 engines up to 1975, it wasnt used in the 76 and up CJ7 with it's different length rear driveshaft. The front driveshat from a 72 to 75 CJ will bolt right in while the rear will need to be made. I did this when I used a T14 in a CJ7 once. I found a donor driveshaft and cut out the extra length in the center. That gave me long sections to run straight edges down to align the two halves with a small center section under the seam. A good even MIG weld all around gave me a free driveshaft in the right size that worked great with no wobble or vibrations.
Here's an idea, what if I got a CJ-8 driveshaft and shortened it? Seems like that would do the trick!
Me personally, I wouldn't feel right about cutting up a good Scrambler driveshaft. I can't remember what I used, maybe a shaft from a T176 cj7 or a YJ/XJ shaft....
I would go to your local pull a part place and find something the size you need or longer with the correct sized u joints and use that.
