Ouch!!
Robert Slone
Spring Hope
I'm leaving in about 30 minutes to go to the hospital for surgery on my left elbow. I have a compressed ulner nerve that's causing numbness in 2 fingers. It's been going on for a while. Been through a series of test to determine the cause. The surgery will involve moving the nerve from the outside bend of my elbow to the inside bend. I'll be in a sling for about 2 weeks.
Good thing is that after it's healed i shouldn't have any more numbness. The same doctor has performed carpal release surgery on both of my wrists for carpal tunnel syndrome.
I'm not looking forward to this afternoon:(
Wish me luck.
Dang, that doesn't sound like fun. I had that same problem, though it didn't end in surgery. I worked on the phones when I first got here, and I would lean on my right elbow while I typed with my left hand - no headsets back then - and I lost the feeling in a couple of fingers on my right hand. It took a couple of months, and a bunch of excercise, to make the pins and needles go away.
Hope it works out well for you. Good luck.
Yuck, sorry to hear this Robert, take care and listen to them on whatever rehab they tell you! Hope it's all done and overwith before too long and you're back to "normal" :crazy:
Good luck!! Sounds like not too bad of a surgery, hope your recovery is quick and you're back to full strength sooner rather then later
Hope everything went well with your surgery. I know well the pins and needles, or electric shock feeling as I call it. Mine's a couple of compressed discs in my neck. Can't feel the 4th and 5the fingers with moving, hope it comes back...
Let us know how the surgery went.
C'mon guys. I went as far as only having to wear glasses. ;)
I'm back :wave:. It went well. The only pain (so far) was the IV needle stuck in the back of my hand. They numbed all the nerves in my arm from my shoulder down which caused my arm to feel like a dead weight. Couldn't use it at all. The feeling came back around 4 this morning. Pain pills must be working well; it doesn't hurt. My arm is in a splint and sling and will be for about 2 weeks.
I don't do anything repetative any more and therapy wasn't helping. This has been going on for a couple of years and had begun to get worse. I was at risk of permanany nerve damage. I have bone spurs on several vertabrae were my neck meets my back. They also cause some numbness but if I stand up straight, swim and do pushups I can keep it at bay.
Sure is tuff to type one handed when you're used to two hands.
Robert, peppers haven't been doing too well. I lost all the Anaheims. I guess it's the heat, but usually it never bothers the peppers. Recent thunderstorms have cooled things down slightly and the bell, poblanos and jalepenos have perked back up. I'm pretty sure I wont make it to Va for the get together, but maybe I could get some to the folks who will make it.
I hope to be going to Ocracoke around the 3rd week of Sept. If you're going to Hatteras then I'd be glad to run over and bring you some.
Pain pills taking affect..gotta go lay on the bed:ZZZ:
Hey Robert S, thought about you this evening. We had a great meal of bacon wrapped scallops, fresh shrimp, & stuffed jalepenos :drool:
Hope you're feeling better.
Robert
I got the splint & sling off this morning and the staples pulled. I can drive again and shower without wrapping my arm in a trashbag!!! Mighty tender still and I have to be carefull what I do.
I started to post a picture but it's gross so I decided to spare everyone.
