Pic Request: Chevy small block exhaust setup
rustycrawler
Reston
VA
I'm looking for ideas/photos/recommendations on how to run the exhaust from the engine back on a Chevy small block conversion. I'm interested in seeing everybody's set up, so if you have some photos, recommended parts, interesting configurations, boring configurations, please post them. I haven't even decided on a dual or single exhaust so I'm open to all ideas.
Thank you!
I just saw this interesting setup in another post.
attachment.php
When I was running my 350, I used shorty street rod headers, and just ran a 90* up front, straight past the transfer case to 2 turbo mufflers, and out in front of the rear tires. Worked but was loud and choppy sounding. On my new 5.3 setup, I'm going 2 into 1- around the front into a y pipe and then out the back corner. Hopefully will be a bit quieter and smoother sounding.
If I'm following you, then the shorty ran inside the frame and it poked out where the frame rises for the rear tires, or were you outside the frame like the picture above? I'd love to figure out how to fit an x pipe in there....currently mine is running outside the frame and poking out right before the tires. It is loud. Photo below.
attachment.php
I was inside the frame, actually went between the frame and the body with a couple of 90* and a 45* so it came out right in front of the rear tire. There might have been room for an h pipe right behind the transfer case, but i didn't put one in.
I thought I had some pics here or at least on my 'puter, but I can't find any.
The glass packs outside of the frame are the loudest kind of exhaust, I think.
Just be careful of using some the shortys because the collector will be right above the front yolk and it may contact the exhaust pipe under compression-
Any idea which shorty does bump the yoke verses which ones don't? I guess it certainly does matter just exactly where my engine is mounted. Is it just trail and error shipping parts back that don't fit? Should I just go custom the whole way?
Is nobody proud enough to post a picture? There has got to be a couple good stories out there. Maybe a few lessons learned?
350 with 1968 327 exhaust manifolds. Crossover pipe before going into a single cat. & FlowMaster. Dual tail pipes exiting between tire & rear bumper. For me it has been an efficient system and sounds nice and mellow without being annoying.
Robert
The crossover on mine is a little different. I'll take some better pictures tomorrow of the whole setup. The manifolds are original "ram's horn" style that were on 283 & 327 ci and bolt to 350, 5.7LT. Hooker and probably Summit Racing too has a "block hugger" center dump style that would work fine. One of these days I'd like to pull my manifolds and get them cermaic coated.
Robert
Hey Rustycrawler...thanks for posting this thread! I was getting ready to post the exact same question myself! I hope some more people will post up some pics.
Robert - where did you go to get your exhaust done?
Best pic I could find, left side. If you keep the bend close to the header there are no clearance issues. These are Hedman "Tight Tubes" headers.
What about chevy v8 to jeep cj conversion headers-what do they look like
do they posibly resemble stock amc manifolds like my edlebrock shortys on my amc 360
attachment.php
attachment.php
Rustycrawler a few new pictures; hope it helps you out. Right crossover is welded into the left exhaust. I have heat wrap around it trying to keep some heat off the oil pan. Tail pipe after dual outlet FlowMaster has quite a few bends but works well.
Mike W. Roy Hendricks Muffler Shop 6309 Horsepen Rd 282-2857
Man, there's still junk stuck all over the underside....."I thought I washed that" :shrug:
Robert
That is a solid looking exhaust. :bow: Thank you for posting all those pictures. Ditto to Randyzzz and Jim. :) If anyone else is just lurking and has a Chevy small block, could you also please post?
My preference is leaning toward running it inside the frame rails.
From a performance point of view I'd like to try to put in an X pipe, but that may just be a pipe dream. :huh: (x pipe, pipe dream...keep up...) Y pipe might be a lot cheaper. H pipe might be the compromise.
rusty,contact me tomorrow,i may have some chevy headers you can have,they were on a cj7 rolling chasis with a chevy 305------------ 540 847 1342
RustyC, I don't have any pix but I'll see if I can grab some or you can swing by and take a look. Mine on CHevy 305 are duels in the frame rails and turn to dump behind the rear tires.
Truck
Truck
Why don't we do both. Post some pics for everybody and I'll swing by and take a look. :)
I've got a wedding to go to tomorrow (no, not mine:cheers:), so if it doesn't happened next weekend, hopefully I'll see you at the Central Virginia get together. Thanks.
