Planning 4.0 Head & FI swap
tower210
Olathe
KS
I have been contemplating ways to put Fuel Injection on my scram for years now; I have considered everything from Howell to Hesco; but have finally decided in my mind to do a full 4.0 head and fuel injection swap. My current 258 is in good shape, and other than the normal issues with carburetors (not so great starting when cold, and less than ideal at inclines when riding trails).
I know lots of 4.0 swaps have been done here, I have read the 4.0 head and FI from JeepStrokers.com and am planning for a swap this winter (finally done with school in June!!).
https://www.jeepstrokers.com/forum/viewtopic.php?f=6&t=24
  • Would you just find a decent running 4.0 and transfer intact (not knowing how much life is left here)?
  • Would you you buy a CHEAP 4.0 head with working ECU and head, dis-assemble, magnaflux, and rebuild like in the Jeepstrokers link?
I know the second one is better, and it sound like it could be done for $700-800 if I shop it. I am guessing the first one is half that.
Which would you do? Is it worth the trouble to go completely through it?
Look for a toasted Jeep Cherokee. Preferably a 94/95' with a manual and the 4.0l. Actually any of the 91-195's will work. Then you are mostly set. Since you are not worrying about the bottom end one with a rod knock is fine. Might be worth taking the head to a machine shop and have them go through it.
There are several threads around to figure out the wiring. Mostly I said 91-95 so you stay with OBDI you can go with the later but it is a bit more complicated. Decide if you want to buy the Hesco Crank trigger or modify your bell housing for the yj flywheel and trigger. You will also need the distributor from the 4.0l.
Several little things but it can be made to work.
Carl
I will buy the Hesco Crank.
How important is a manual ECU? There are 90% automatics.
Will a machine shop really be able assess the condition of a pulled head?
I appreciate the input....
Is there a chip available for the stroker crankshaft combination?
Sent from my SM-G920V
Do what CBRogers said. I got the majority of what I needed from a dead '94 Grande Cherokee. I think the wiring harness is a little easier to work with from a regular cherokee, though. Bring the head to a shop for a valve job and general clean up. I used a computer from an automatic, and it works. I also used the crank sensor from Hesco.
All in all, as you would expect, it's approximately equivalent to a jeep 4.0 engine. There is definitely more power and better gas mileage not to mention the way it cranks and goes on a cold morning.
https://www.cj-8.com/forum/showthre...n-and-Head-Upgrade-on-4-2&p=301689#post301689
I just bought and had a 7120 head rebuilt and I would say definitely get the head checked out. Mine was not cracked but it needed to be shaved .005", all of the valve springs were worn and twisted and it needed a valve job. I spend $150 on the head and about $450 in head work. The good thing is I know for a fact the head is in perfect shape not and will last me a long time.
Trick to getting the OBDI computer to work with a stroker is to upgrade to Ford Mustang injectors. They flow more at same dwell time. So there is really no need to worry about that issue. Rebuilt injectors for the 5.0l mustang engine are dirt cheep on eBay from those places offering cleaning services. You will get a pack of 8 so you will have 2 extra.
The Automatic version will work fine. It revs a little higher at idle and there is a small issue when wiring the Neutral Safety Switch. bit it will work OK.
The JB weld thing in only required on some blocks. Usually the more early the casting the more you will have to plug those outside coolant passages. You can drill round and put in freeze plug, try to JB weld or Marie-text epoxy. If you have an 86 or later 258 variant then the deck surface is wider. They were doing that when they moved to the 4.0l block. For some reason the early 258's were a bit narrower and do not support the outer surface of the head gasket fully and will allow coolant to seep out. Those passages do not go into the block from the head so closing them off does not hurt.
The 7120 is a pretty bullet proof head, but it is always good to have a machine shop go through it when doing any big engine work. Just cheep insurance. Usually they can do a quick overview and let you know what they think it will need. As far as the epoxy. I would have them do cleaning and head work then do the filling on your own. Or have them drill for the freeze plugs. Should not cost much more since you are having them already do other work there. For what it is worth, I think having the passage welded is way overkill. It is only a little unsupported there.
Carl
Anyone have experience with the edelbrock head?
So did you JB weld the passages before they shaved it?
No i did it after so they could get al the passages fully cleaned. I let it sit for a coulple days and then smoothed them out before mounting the head.
Sent from my GT-P5210
Depending on what the machinist does, you will need to measure for new pushrods. I bought a pushrod length checker from Jegs and measured both the intake and exhaust to find out what I needed. You cannot use the 258 stock pushrods and if the machinist decks the head and does a valve job then the stock 4.0 pushrods won't work either.
On my '85 CJ7 with a 4.0 MPFI head swap I just used JB weld with water soluble packing peanuts behind it and have not had any issues. Just make sure to have the area inside the coolant passages is really clean beforehand. The head was cleaned and rebuilt before the JB weld went in.
For the CPS, I went with Hesco's. I'm also using their adjustable fuel pressure regulator (pre-set to 44psi). For injectors I went with those originally intended for the 95-97 Dodge Neon & Stratus (part #0280155703). They are a direct swap for 87-98 4.0s. They have 4 spray holes in the nozzle and are supposed to atomize the fuel better. The electrical plug on the injectors is the same so it truly is a direct swap.
I spent a great deal of time gasket matching, cleaning up, and slightly porting my 4.0 head and intake. It also has a bored 62mm throttle body.
The 4.0 head and MPFI have been on the Jeep a couple years now and overall have been very happy with it! Would definitely recommend it!
I did eliminate the underhood PDC to further clean up the wiring. The two fuses needed are mounted near the starter solenoid and the two relays above the back of the valve cover on the firewall.
Sent via smoke signal
That is a really clean 4.0 Head install. Where did you hide the ECU?
The ECU is up under the dash above the heater box. It's in approximately the same location as the original carter BBD computer. I ran the wiring through the original hole in the firewall where the carter BBD wiring went through near the battery above the heater hoses. I did have to slightly enlarge the hole in the firewall with a dremel for the 4.0 ECU plug to fit through but was still able to reuse the original grommet.
I did the same, but simply used bread instead of the peanuts. The dodge injectors work great. You can find cleaned, bench tested sets on ebay.
UPDATE!!!
Guy near me selling a recently machined 4.0 head off a 1997 GC. Says he already sold the fuel rail and injectors; but it appears he has almost everything else I would need. I texted him and he had the head rebuild thinking that was the problem and turned out to be a blocked water passage; and then he junked the whole car.
Pretty sure I would want the head and intake (how to I make sure he isn't lying about what went wrong to kill his 4.0?). Machine shop that did the work may be able to inspect and verify.
Would I need both O2 sensors if I am using a OBD1 ECU?
Running HEI now. Would I want his distributor & cap (I'm pretty sure I do)?
Is wiring harness the same as for OBD1 system (don't think it is)?
Don't think I need pulley (figuring I would buy the hesco harmonic with pickup)?
I am curious why they pulled the rocker arms.......
Any help would be appreciated!!
Jeepscrambler
Jeep parts - 4.0 Straight 6 engine parts (Kansas City)
I have a handful of parts from a jeep I sent to salvage - Freshly machined head, with receipts, 0630 or 0620 casting (will have to look and verify #, it's the factory head from that year). It came off a 97 Grand cherokee, so it will fit many years of the 4.0 motor. Also have the valve cover, rocker arms, 11 of the 12 pushrods, distributor, cap and rotor, serp belt, balancer pulley, air box, front and rear oxygen sensor, coolant overflow tank, hose and level sensor, front driveshaft, intake manifold, ECU and wiring harness. Fuel rail and injectors are sold. Looking for 250 for the head (400 in work done on it), all else is negotiable
I just sold my kit, but I posted all the parts required for the swap along with part numbers in my ad. It's in the for sale section. As far as the head is concerned, I drove my buddys carbed 258 with a stock head, then the 4.0L head swap (stayed with the carb) and can honestly say I didn't really feel much of a difference before vs after. On my jeep I had a stock 258 and drove it for a while with a weber 38 carb, then went to the mopar mpi and it made a massive difference in power/gas mileage. I retained the stock 258 head. I'm sure the 4.0L head helps ish, but I very firmly believe the real gain is the mpi. People get very caught up in flow numbers, but in reality when you're only talking about low engine speeds around 2-3,000 rpm. The little bit of difference in cfm really doesn't matter that much. The only real advantages I see with the 4.0L head is the smaller combustion chamber to increase compression. That too doesn't really add a whole lot to an engine under 200hp. In my opinion, if you have a good healthy 258 just leave it alone and swap on the efi. You wont regret it.
From Hesco
Speed Sensor #HES7015 $122.
Speed Sensor Connector # 4414048 $23.49
91-95 Fuel Pressure Regulator #HES9195FR $179.
4.2L DAMPER/CRANK SENSOR KIT HES42VED $329.
Crank Sensor Connector #56016983 $23.49
Fuel pump block off plate/coil mount $23.00
From Autozone
Reman Distributor $59.99
Duralast Spark Plug Wires #1600 $15.99
Delphi Fuel Pump CFE0108 $71.99
Spectre Universal Air Filter $24.99
Duralast 195 Thermostat #15358 $7.99
From a friend
Used LT1 Fuel Injectors (recently pulled) $50.
From my local yard
Used Harness, Computer, Intake, Throttle Body, Fuel Rail, Coil, Map Sensor $100.
