- Cincinnati
- Oh
This is for all you Carter BBD haters. When we got her a couple months ago, she wouldn't idle for anything. Word had it that the previous owner's neighbor poured water in the tank, but he maybe didn't know it. He sold it to Mr. Beep for cheap. Mr. Beep discovered all that nonsense, cleaned it up, dropped the tank, cleaned out the carb, etc., then sold it to me for cheap (with full disclosure). It had a brand new Carter BBD, and a new fuel pump.
It had developed mold of some sort in the new carb, which in turn corroded the float bowls. They would then oxidize and precipitate a black granular sandy goo into the bowls, where it would be sucked up and plug the idle tubes. Hence, no idle. It would run fine at speed, but stall at every stop.
Lucky for me, Sam the Boy had installed a Weber on a friend's YJ awhile ago and stuck the old BBD on the shelf. I was able to cannibalize the old carb's midsection and grafted it into the top and bottom of the new carb. I also drilled out the idle tubes (#67 drill bit). Put it all back together today and it works like a charm.
That should hold me off until I can install the Howell that showed up this week. I also did the Nutter bypass and the "Team Rush" this week, plus replaced a seatbelt. Now I am sorting through all of the extraneous wiring from the computer that will go away soon. What a gaggle of wires.
For those of you who haven't fallen asleep yet, thank you for listening.
