Project BT3-Caboose
Thanks. Hoping to put it to use again soon and looking forward to getting the electrical/lighting done. Got to source a good tongue box before that can happen.
Finally found a tongue box I was happy with. This is mostly for the electronic stuff (battery, solar charge controller, switch system and junctions/fuses). Now to get it mounted and some MDF inside for mounting things easily. 1A512379-F22A-4C6D-A4DA-47901C81A2F9.jpeg
Memorial Day weekend camping trip to Jeep friends’ place in Indiana.
7879597E-99A7-48CA-ABC1-97C4AB2FCA01.jpeg AE0445DC-DD8A-4EC6-8253-1D56193009FD.jpeg 0518158B-4132-4B96-BFDC-7A7E784AA783.jpeg 280F70A8-A1F0-4B29-BABD-76BB4F9E8A2F.jpeg 96F40A43-E436-4CC1-A92B-22C2531FB709.jpeg
CJ7Pilot
18436572
Yuba City
CA
#44
Nice! That trailer is quite the setup.
I imagine a few of us will be heading down that road in the near future.
Following the Africa trip in your magazine is a great insight to what is needed to live out of a vehicle, and how well certain items work.
I have a cousin who is setting up a van for long term living, and I referred him to TheRoadChoseMe.com, and he took a ton of good info! :thumbsup:
Trailer did great even though we were really just sleeping there and hanging at out friends’ house most of the time. Remarkable how big a temperature difference there was in the sun in the morning between the annex and the actual tent. Too hot too early in the year!
03B039C7-DEA6-48C7-AAD7-DCC6C40047F5.jpeg 97F8B593-3F47-46B9-8BE7-A377C4D0A45D.jpeg 082FFC13-2949-47AC-B4C7-5384C318086A.jpeg 0B16F320-ED54-4F5A-AEA8-BD3ADB43C493.jpeg 6B3A01D8-CE2A-4D7D-AB24-966A71108270.jpeg B3424F68-26B5-4DED-A1B6-BA405F14D573.jpeg DB685246-6F6F-4A81-BCDC-C49674FBD215.jpeg BFF0E933-CE91-4194-8D51-2F0F0D38C21B.jpeg 7932FB04-A716-4DB3-B420-5624622C5E53.jpeg 58A30D6B-78F9-4611-A349-2BC539607227.jpeg
Wiring time! Lots of stuff to wire up between the scene lights, bed lights, switches, rock lights, reverse light, fridge power, solar charge controller, house battery, trailer brakes, and the removable trailer plug
Came up with a very interesting setup for the tongue/tongue box, more to come there.
Mounted a 3.5" RR LED flood in the stock taillight hole for the reverse light on the trailer.
Wiring is FUN!!!
I'm being anal about testing everything between the major steps and that's really slowing me down. I checked everything before messing with the conduit and routing the wires to the box and then again over the last couple days with all of the wires run through the conduit into the box, but without finalizing any component mounting (other than the Odyssey) or shortening/securing all the wires. (That's why you're seeing wire nuts, don't give me crap on them.)
I have a piece of marine plywood cut for the inside front of the box that will let me mount the components without adding more box holes and the next thing is to move the components to that and start finalizing wire length/terminations.
I only forgot one wire so far, I wanted a heavier ground between the trailer socket and the frame, but I was able to get it through without much trouble. Everything else is going to plan.
Lots of cutting, crimping, soldering and screwing in my future.
There are a couple things I want to clean up more before I call the wiring “done”, but everything wiring related aside from the trailer brakes and controller install is in and working.
Finished up too late tonight after a very long day to want to try to drag it out for proper photos but the trailer battery is charging off the Jeep when connected via the power umbilical and the solar panel is working great (plugs into a socket in the box).
I built two “extension cords” that also plug into sockets on the trailer box to run 12v power with two USBs each and a power socket for an inverter or whatever back into the tent.
The trailer has four LED cubes for scene lights, two repurposed LED rock lights as bed lights, an LED backup light and rock lights underneath that are triggered by either the Jeep dash switch (installed 6 rock lights on the Postal) or the Trigger switch unit in the tongue box.
The fridge is powered up properly and I ran some LED strip lights on a pin switch to light up the tongue box.
Hated cutting into the Postal to mount the 7-wire trailer socket, but it was worth it.
I already dig the rock lights under the Postal for working under it and I can tell we will use the trailer rock lights for low-level campsite lighting.
The Bluetooth control for the lights is cool and the phone app is actually pretty sweet.
I got a Bluetooth battery monitor too just because I’m paranoid and it was easier than wiring in a voltmeter. Pretty slick setup, I have to say.
A904C7F3-836C-4DC8-848F-2AE19431D98A.jpeg 58E0351F-D0B7-4D54-9236-476F246CBBCB.jpeg 59BC6C38-E0F4-400F-B6EE-BFC594B741D3.jpeg 3F53E7E2-2DF3-49D6-979F-6C2EC6AA3514.jpeg 0849E7B9-1EB2-481E-A9AB-0DC93B7F3F08.jpeg
