- Bedford
- NH
I found a box of mismatched body mounts and got to work.
There are 12 mounts... I now have 8 in place.
The fronts and the rears and a couple in the middle.
2 I can't do right now as the floor needs repair and the channels need replacing.
The other 2 are slightly larger diameter mounts as they are part of the floor and they used 7/16" bolts instead of 3/8" stock ones.
I have a lot of 7/16" but not in the length that you need.
If you put too long of bolts in there, they will go through the floor.
I ahve done this not once... but twice in my 1" body lifting career.
Don't drink and lift!
Anyway...
It goes without saying that the car hoist/lift makes this a LOT easier of a job.
I tried to get an exact side shot to show the wheel openings.
These tires are 32" and I will run 33" ones... if you measure we are kicked a little forward here, but the shackle is straight up and down due to the lack of weight.
Also the wheel base is off by about 3/4-1" total right now due to the lack of weight on the frame.
So, once this all relaxes and has weight on it, the tire will/should be in exact position.
I am pretty happy with all that has gone on... body mounts all lined up so far.
I will have 10 of the 12 done by tonight once I get some more hardware.
The other 2 will have to wait until the floor repairs are finished up... but this is a weight off my shoulders as you can measure a thousand times, but until you try to actually connect it, you don't know.
And when you start from scratch with a pair of frame rails, and slight offset could cause a lot of headache.
Anyway...
I tried to get an exact side shot to show the wheel openings.These tires are 32" and I will run 33" ones... if you measure we are kicked a little forward here, but the shackle is straight up and down due to the lack of weight.
