What kind of heat ? Wood, oil or electric ?
, but the piggy bank is empty at the moment... thus the new CJ7 to the mix to teardown and sell some parts.Being directly west by 45 minutes, I am not sure how you get any time outside wrenching in the winter without heat. My shed is unheated as well. I joined my local makerspace so I could have a warm space. You are tougher than me.
I was thinking the same thing. Heat pumps don't use much wattage for heating, but there has to be enough heat in the outside air for them to be effective. Curious what the pros in NH think.Realize different climate, I have had great experience with mini-splits… keeps warm even in teens outside and cool over 100 outside… might be able use an supplement with gas BTU in winter and use AC in summer, which helps with humidity…
We have natural gas here so i have that setup for the house, gasheat/ac unit and love it, plus gas stove and water heater. I'm hearing the environmentalist want to eliminate that in new home construction. Gas is cheap around here.
Especially since I hearing we have a couple few hundred year supply on this continent.Can’t see the point in banning natural gas in homes around here. Most of our power plants are natural gas fired steam turbine generation units. Moving the burning of the gas from a home to a power plant is ignorant green peace tree hugging fallacy.
I am in the process of installing a natural gas line to my house to run a 24kw generator, 400k btu pool heater, 3 furnaces, 2 hot water heaters, and a clothes dryer. About 1.3M btu in all. Gonna be burning gas like it is going out of style.![]()
Does anyone have a source for new ones of these gussetsNot a lot of time this week with the weather and work, but all in all, rollbar out, some flooring removed.
And a whole lot of removal of bolts and separation of pieces... none of these bolts would turn even with heat... rust is fun!
Last I knew, they don't remake these... so you have to make your own, or repair what you have.Does anyone have a source for new ones of these gussets
I know a guy that had some makeup in Morgantown, PA. Had them on ebay and FB marketplace. not sure if he has any left.Does anyone have a source for new ones of these gussets
