Questions about the NOS proportioning valve I bought?
Even the brass ones don’t have the part number. Does that one you have NOS have it? I still also need to run the long part number for you. 89 prefix tells me it’s late in the amc run.
Yes it has the part number looks like it starts with "W" in an octagon then followed by SF-3229568
Then below it it has the numbers
7. 1. 335. Kinda spaced out like that
On the opposite side it has the number one stamped next to the bottom bolt hole.
The one on the '81 frame that's easiest to see has a number 3 stamped in the exact same place the number one is on the brass one.83508.jpeg83508.jpeg
When I get a chance I'll pull the one from the '81 frame and see if I can find a number or anything stamped into it.
I was guessing the "W" in the octagon on the NOS one was prob a Wagner symbol. I bet they farmed these out to them.
W may be Weatherford - seem to remember that name from somewhere
This site has good info on brake equipment, too bad he didnt have a rebuild kit for mine, but some of the internals are the same as the GM units.
Unless I'm losing it and yes I'm getting old, all the ones I have cleaned up over the years on the wire wheel etc i dont remember seeing a part number. Not in the shop now to check one in the cabinet. its possible this later NOS one you have they started stamping PNs or they only did from a certain manufacturer... @certifiablejeep can you check you stack of them ? :)
I did try to run your part number and wow is that an oddball. All the way up to 1996 i couldn't get a match on either PN. and its for sure not pre-74. But the PN prefixes do indicate its a Jeep PN. So the jury is still out on that.
Ok this should clear some things up. This is the one from my ( what I think is low mileage and original) '81 Scrambler that has been parked since '92. After I got it off and cleaned it up I found the grey was just corrosion and it was actually brass. I swear as that stuff came off I felt pretty dumb. Lol but you have to admit in the pic I posted above it did look aluminum. Anyway, after cleaning it I did find a part number on the back side. 5359220 ( I hope that's right and I didnt sand off a number) also below it had
81. 070.
I'm guessing the 81 would be the year?
The other one has 71 in the same spot?
Sorry for all the confusion. I still wonder about the rear port being bigger on the NOS one. At this point I bet its not for '82-'86 Jeep CJ as it was listed, oh well it's not the first part I have bought that wasnt what it was suppose to have been,I'm sure it won't be the last. Lol
