Quick Flattie!!
And I thought going 70 mph in my CJ8 was unsafe with high-backs, 3-point belts, a cage, 50% more wheelbase. That flatty must be scary as hell at the end of that 1/4 mile!
that's the "no" club for you....
no helmet + no roll bar + no seat belt = no brains!!!
but in your defence....center of gravity waaaaaaaaaayyyyyyyyyy lower.....and probably not as much horse power.
It was enough! First to second would pull the front end off of the ground if you pushed the footprint gas pedal down hard enough and dropped the clutch.
I drove the snot out of it. It'd beat you to death, though. 1400 lbs, 289 hi-po out of a 67 mustang, four speed, offenhauser tunnel ram with dual edelbrock 500s. 15" wide Mickey Thompsons in the back and 3" motorcycle tires in the front. There was no "subtle". You sat four inches off of the floor and drove with your elbows resting around your knees. Try that position sitting in a chair. Pull a knee up until you can hook it with your elbow. Now imagine driving like that! It was a rush though. Top speed was only 80-85, but it'd walk anything that pulled up stoplight to stoplight.
