Not a lot of time to work on the 7 this week but I thought that I would post my short list and see what what you folks think.
1.R2.8 to 6L80e adapter from AXIS IND. .This consists of a bell housing ring, flywheel,center piece and then an LS flywheel. Not sure about how I feel about multiple parts and two flywheels but seems to be the only option at the moment.
2.6L80e to Dana300 adapter from AdvancedAdapters. I believe the adapter has multiple clocking positions and also has the transmission mount. I have heard that the Dana300 is prone to leaking when clocked. Is there a solution for this ?
3.Engine mounts from AXIS IND. Engine side only. Not ideal but easy enough to fab the frame side. Wondering what the best kind of dampener is for the diesel vibration might be?
4.Turbo intercooler from ??? AXIS IND. say they are working on a solution that includes brackets, intercooler and trans cooler but not sure how long it will be. At the moment this is an overwhelming item because there not a lot of room in the grill. Somehow AC condenser ,intercooler , trans cooler and radiator/electric fan(s).
5.Radiator and electric fans ??? There is a boat load of options and a ridiculous range in pricing for this. I would prefer to have the (aluminum)radiator, fans and shroud come as a unit. The price range that I have seen is $300-$2,400 .The recognizable names (Griffen,WizardCooling,Flexalite ,etc.) are on the higher side of that range. The lower range consists of EBAY ,AMAZON and few other random search results. What are your experiences ?
6.Fuel system. I have been told the high pressure pump will draw fuel from the tank. I know that the 5.9 will do this but it isn't good for the pump. Maybe AirDog or Fast in addition ?
7.AC/heat . Vintage Air?
8.Drive shafts . Not sure about where to get these.
9.Keyed ignition sorce. In the column or in the console?
10.Exhaust . Wait and see where everything falls.
That is the short(ish) list. I am sure that there will be additional items but I think this gets it running. All help and advise is appreciated !! Thanks.
