Rain and motor issue
Rock-N-Roll
Excuse my ignorance but what and where is my intake system?
I have attached a photo with a high lighted area - is this it??
Thanks.
Your question regarding the photo is correctly answered above, (by Spankrjs).
I am/was referring to how your engine is supplied with intake air for combustion. If you have an unprotected aftermarket air cleaner, (such as a K&N) or a stock air cleaner that does not have the rectangular intake hose attached.........road spray/rain can cause the type of problem you described.
It won't hurt for you to put a small amount of di-electric grease inside each spark plug wire - at both the spark plug end and distributor end.....as well as the coil wire ends. (does the same thing as WD-40, but is a more permanent moisture barrier. If you have any cracks in your spark plug wires, its time to replace them.
Is there any way road spray/rain can get into the distributor between the cap and distributor base? You can make an inexpensive shield by putting a piece of duct tape around the joint. (I don't know what type of ignition system you have.)
Not being there, all I/we can do is throw out ideas.
Wayne - Sounds like you coverd the engine with your water hose testing. Did you do as Sunnshine suggested? Try checking on the fenders and firewall areas. Your ignition box, starter solenoid, or one of your system grounds could lose contact with moisture and would make an intermitent problem.
Ignition box in particular if this problem only happens when motor is all warmed up.
I appreciate everyones input. After doing what you all suggested I may have solved the problem? I have been to two storms since and, so far - so good.
Cheers.
