Removing the diagnostic connector and wires...
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
Anyone see ANY reason for keeping the diagnoctic connenctors (good link) (the two electrical connectors with yellow caps that no one ever uses) on the engine?
In preparation for a Taurus fan install and a MC2100, I'd like to start cleaning unneeded stuff out of the engine bay and this seems like a good place to start. At least on mine, this thing occupies some prime real estate right on top of the right hand fenderwell and it has a MESS of useless wires associated with it.
I don't think I'd trust the 20 year old wires anyhow if I did want to check the voltages on the things attached to this jobber, so I'd want to go right to the components themselves anyway...
Just checking to see if there's some reason that I may have overlooked before I start on this tonight.
After my brake debacle on Saturday I decided to go ahead and re-install my wiring harness since I knew it would fit right, and was wondering the same thing about that plug....
The only advice I might give you is start your jeep up and cut the wires one at a time to see if anything bad happens....If it doesn't cut off or explode, I'd say you didn't need it anyway....:eek:
Bill
If you think about what they are: a bunch of open-ended, non-connected wires, there's no way that any of them can be used for anything or cause any problems if removed... they ain't connected to nuthin!
I think I'll cut them all out tonight and rebundle the wiring harness that's left.
On a related note, I heard a good reason to get rid of all of the corrugated black wire loom junk last weekend... if you ever have a wire in there that had a crack or nick in the insulation and you get water up in the loom, it will just sit there and wreak havoc with the open wire. Removing the loom allows any water to just fall away from the wire straight off...
I can see that stuff protecting the wiring physically though... maybe just cut small holes in the bottom side of it to allow it to drain...
Bill, I absolutely Love that approach:D
Eric, my wire loom is yellow :D I got sick of the engine bay being grease color
I have more wiring to remove, I'm POST Nutter, BTW
I'm sure more can go but am finishing up the more important things on my (drastically shortened) list
That sounds like a good plan Mike, get to the real stuff before the nitpicky junk. Mine is running ok and I have some time to make things better rather than fixing problems... I also want to make room for the relays for the Taurus fan :D
I agree that the plastic wireloom can create some problems with trapped moisture and debris....I gonna try something else when I get to that point. Panduit sells some stuff that looks like a plastic spiral spring. We sell it where I work, but we don't stock it...I'm gonna have to get some "samples" when I get to that point.....
I pulled apart all of the wire looms under the hood last night. It was great because I wasn't in a hurry and took my sweet time tracing all of the wires.
I now have a MUCH better feel for how the wiring works and I managed to pull out a couple of pounds and probably 60-80' of wire all told.
For reference, most of the wires in that diagnostic connector run into the main, fat wire loom that runs across the top of the back of the engine bay to splices in the wires that run between the sensors and the computer. I found that the splices were all covered in duct tape of all things, but the splices themselves look pretty solid.
I don't see any reason that you couldn't just cut all the wires to the diagnostic connector right there where they enter the main loom, but I was more thorough and got them back at the very end of each of them. A couple run all the way to the sensors themselves, so it was good to get all of that wire out of there as well.
I found that there is a red wire in this bunch that is a switched positive, so I left that one in and just heat shrinked and labeled it for possible future use. Another thing I found is the switched positive that I tapped into for the HEI. I took out my original connection and redid it with the fatter wire that runs straight off the firewall connector, this shortened and cleaned up a wire that really had been annoying me. I also pulled the high altitude adjustment wire out of the loom and bundled it up out of the way to clean up the wiring just a little more.
Finally, since I've done the HEI, I have spare parts for everything for it except the base of the dizzy, and don't see myself ever going back to stock, I bit the bullet and cut out all of the stock ignition crap.
I now have a pretty good idea of what all I'll be able to get rid of once I have the MC 2100 installed and I'm REALLY looking forward to that! Getting all of that junk out of there will REALLY get rid of some wires, not to mention all of the vacuum stuff. Now I'm totally psyched for that upgrade.
Thanks Eric...
That's good, detailed info to have! I need to be doing the exact same thing... over the winter I suppose.]
FWIW, while I am going to give the MC2100 a trial on my brown Scrambler, I could not be happier w/ the Carter YF 1bbl's performance at Oak Ridge. Performed like a champ w/ nary a hiccup. Plus MPG is W-A-A-Y up - close to 18mpg I think.:) Not a highway powerhouse, but still able to easily exceed speed limit... just takes a little longer to pass w/ no secondaries.
Note from personal experience:
If you are running an aftermarket carb (mc2100 or weber) and an aftermarket ignition (MSD or HEI) then you can SAFELY cut the diagnostic connector at the bulkhead where it goes in towards the ECU.
Once you have cut that bundle, it's easy to trace all the non-used wires back to the block, and prune them.
I have successfully completed this on 3 Jeeps thus far... It's GREAT to see the owner's face when you walk up with a set of lineman's pliars hack the whole thing and hand him/her the ECU... :D :D :D
I CAN'T WAIT FOR THAT DAY!
I was just getting tired of looking at the connectors sitting there on the fender for no good reason. I needed to start moving in the direction of getting those stupid wires out of there. :D
