Replacement motor in and running
Marine-OpLaw
'ANTIQUATED' PackRat
Fredericksburg
W/ Truck coming over and giving lots of valuable assistance/suggestions, we got the used 258 replacement motor in and running. Noticed a host of leaks on start-up: valve cover, manifold, vacuum, etc... but it RUNS! Start on the nitnoid stuff tomorrow.
[Sorry Eric, no pics.:( ]
Unfortunately, on disassembly the center grill bolt was frozen in place and the capture nut broke loose...:mad:
so still have to fix that, get leaky radiator fixed, install TR ignition upgrade (big dizzy cap, TFI coil & HEI-type plug wires), tweak timing, replace tranny mount & torque bolt, and... ah heck! the list is never-ending! :rolleyes: :mad:
But we WILL be ready for Oak Ridge! W/ Truck riding shotgun, heaven help the poor guy(s) in front of us! [snicker, snicker;) ]
MANY THANKS TRUCK for the help and fellowship!:) I guess the Air Force does have some worthy guys!;) Probably a Marine at heart, but just got into that other service by mistake.:eek: :p
Well, not sure how much help I was...but I did enjoy handin' you wrenches and twistin a couple of bolts in for you. At least she's in there and starts. You'll get all the tweakin stuff knocked out easy enough. Good day, good work.
Cheers,
Truck
Congrats Jerry, that's good news indeed. You should definitely be ready for Oak Ridge if those are the only kinds of things you have left to tweak.
It feel really good when you turn the key and you hear it fire up. I know everytime I have done a engine swap over the years in different Jeeps I learn something new. It feels really good though when it fries up and you know the hard part is though and over. Grab yourself some manifold gaskets, and valve cover gasket and plug those leaks...
TK
tom keyes said:
It feels really good though when it fries up and you know the hard part is though and over...
TK
Personally, I'm going to feel really BAD if my Scrambler fries up when I get it going again. That would suck. ;)
Craig
TK
I will always remember the moment that I got my newly-purchased, non-starting, non-cranking, I'm-supposed-to-be-driving-this-thing-back-across-the-continent Postal to finally crank and run!
That is one cool feeling...
