- Redmond
- OR
After much consideration I have decided to go with a 9” rear axle on Red. I have a question on width that I can’t seem to find good info on. I know the stock WT front is 56” wide, and the rear is 54.5” wide. Why wouldn’t you want the same track front and rear? I know that supposedly a narrower rear gives a better turning radius, but that didn’t seem to make a difference in Copper ( both axles same width) plus in the snow it seems to track better following the front ruts instead of the rear bouncing left to right following one of the other ruts. The reason I’m asking is getting a housing narrowed locally costs more than a fabricated housing from Speedway. But Speedway has either 54” or 56”. I’m leaning towards 56”. Your thoughts?
