Rim opening too small
Scramblin_Jim
Goodyear
AZ
Surprise surprise!
I found out yesterday as I was moving tires around on my 8 that the spare tire would not fit over my hubs. Seems the rim is different and has a small diameter opening, maybe about a 3/8 to 1/2" smaller opening. The bolt pattern is still 5.5. The rim itself has a different offset than the others, not the -19mm. As I look back on it, when I purchased the Scrambler, it had a military tire mounted to this rim that was rotted and I just simply took it off and mounted my 30" Wrangler on it.
Boy sure glad I never needed a spare while out four wheel'n over the past 18-months! :eek:
yes but!!!! when you purchase a vehicle you assume that all the rims will fit the vehicle. If I knew the spare did not match and just threw it in, I'd at least let the buyer know. But then again, there are just too many people out there with less than perfect integrity. :rolleyes:
It should fit on the Rear and you could swap the good rear to the front.
Might have been that the PO had only tried it on the rear, or maybe not even have been on the axle. Must be an old Ford rim.
You can get it enlarged if need be though.
Carl
