Rubicon Express 4.5" with 35" tires
I'd just install the longer anti-wrap and not those. You lose the ability for the axle to keep from rolling(and wrapping) with the shorter pads and the adapters above....
What is the longer anti wrap. Is it a extra spring (like the helper spring on a truck) that has a hole and a stem to move the axle back but extends out longer for support.
M.O.R.E has the longer spring plates (3 hole). I noticed on there web site. A nice way to get a inch to the front or back if you were putting new spring plates on.
They do look heavy duty compared to the stock plates. Something to think on. Thanks.:wave:
I'm thoroughly confused now. I thought the M.O.R.E. plates relocated the axle forward. But someone said not to move the axle forward. Is the idea to move the spring forward and keep the axle where it is - reducing the amount of backward movement?
Holding off on firing up the jigsaw for now...
I just saw you're thread and was going to point you to this. The plate I have a link to (above) is about 4" long. It has a center pin in the middle of it and a hole about 1" on either side. If you put the plate on the bottom of the life spring mount (pin going into the mount), then put the leaf spring on with the spring pack pin in line with the front hole (of the plate), it moves the axle back about 1". I had to go to my shop where I just removed the U-bolts to see and understand. If you want to make it stronger (help with axle wrap because of longer spring mount) M.O.R.E makes a 6" mount with three holes so you can move the axle in one of three positions (must cut your mount off and weld these mounts on if you go the 6" mount route). http://www.mountainoffroad.com/_e/L...af_Spring_Mounts_Fits_2_1_2_axle_diameter.htm this is the link more the mount (I just picked one, I don't know the diameter of the amc 20).
Yes the MORE axle pads do move axle forward. If you don't, the tires will rub the back of the wheel wells as you know already. To work the springs well, you really need to move the front hanger forward about 1.5" too. That would allow the 35 to go to the top of the wheel well when the spring goes flat.
I do wish I could weld good enough to install. My welder just had a cutting blade slip and cut a tendon. He's out of action for 6 weeks.
Sorry Manhattan, On you're picture I thought you were running at the front of the tire. Everything I said was correct except you would use the rear hole which would move the axle forward about 1'. Thanks Mysunnshine.
The pic I have posted with my Jeep flexed has the axle moved forward already. It's still not enough for the springs.
I don't think he wants you to move it forward
Sorry I was confused about the picture, I thought that was the front of the wheel-well , I understand now
The MORE plates can be used to move the axle either direction.
