I recently bought this 1981 CJ-8 at an auction. A previous owner changed all of the drivetrain. It has a 360 V8. I believe the entire drivetrain is from whatever that V8 came from but I don’t know for sure. Both front and rear axles have been changed. The front axle is 54” from backing plate to backing plate. The rear is 52” and the pumpkin is offset! The vibration is coming from the crazy stupid angle of the rear driveshaft. From the offset pumpkin to the trans is probably a 12’ difference left to right. So the rear driveshaft is a bit sideways. It’s crazy. Anyway, I removed the rear driveshaft, and put it in 4WD high and it drove fine. Well, kinda. It has no sway bar. That’s right, None. Zero. It sways like a boat. It’s a very nice looking parade vehicle at this point.
So here’s what I want to do and I’m hoping I can get some advice on how to get there.
Choice one - sell it as is.
Choice two - fix it so it’s road worthy. I know I need to replace the rear with a centered pumpkin so my driveshaft is straight.
I need to install sway bar in front. The challenge here is that with the current axle set up, the leaf spring mounts are outside of the frame! I’m not comfortable with that. So I’ll need to source front and rear axles. OR - can I have the front axel’s and housing shortened and move the spring mounts back to where they’re supposed to be?
I’m not afraid of any of it. Just trying to determine the shortest distance (time +$) between where I am, and where I wanna be. Thanks for reading and thanks in advance for the advice.
