We got addicted to Sirius after Kate's JK came with the free trial and now I get physically ill when forced to listen to commercials now, totally hooked on it.
DO NOT GET FM TRANSMITTERS. Tried a number of them, they all suck donkey and even when they work, they can't remotely compare to hard wiring it.
My understanding of the iPhone setup from when I looked at that option was that it uses your cellular data to get the radio feed over the web, so you're using your data allotment whenever it's running. It's not doing actual satellite radio and will be dependent on data signal that's much sketchier than satellite signal.
It's very nice to have it all integrated to the receiver like in her JK, for my LJ I got the add-on package and mounted it on the dash beside the stereo and ran all the wiring hidden into the dash. I got a spare mounting kit/antenna for it and can now swap it into the bus and the Cherokee too (both of the cheap stereos in those have AUX inputs). I haven't bothered with the Scrambler yet, but no reason I couldn't use it there too.
I can tell you that it's very likely you won't move the mounting kit from vehicle to vehicle very often, I'd get one for each vehicle you would want to use it in.
So my advice would be the cheap standalone radio with extra kits if you really want to have it in other vehicles. If you really want it in just the one, go with the actual dash unit and removable face.
