Skid Plate (Transmission support) HELP
84jeepscrambler
84 Scrambler 68 Mustang
Kutztown
PA
I am still performing the tub off restoration of my 84 Scrambler (258 I6 to 360 V8). I lowered the rebuilt 360 onto the frame and started to put new cluth kit with the 360 flywheel and my rebuilt T176. I go to put the skid plate on to support the tranny and the holes in the skid plate aren't mathing up anywhere??? I have a total of 6 holes (3 on each side) on the frame that I thought would adjust foward for the V8 (shorter block) then the straight 6... When I set the skid plate in the forward most position the plate misses the holes by about an inch... The plate hangs about 2 inches outside the frame on both sides??? Do I need to cut the skid plate???? It is the stock skid plate from looking at others...
Thanks
84jeepscrambler
DAN
#1 Get a better tranny, that T-176 isn't going to hold up long. (T-18, NP-235 would be a better option)
#2 Yes you will need to drill some new holes in the skid plate.
#3 No you don't need to trim off the sides.
That's a NP-435 Mark.
Hi Dan,
I agree that you really don't need to cut the sides. I have the same set up in my 84 CJ8 360 + T176. I have about 1" overhang on either side. I am using the front 3 frame holes. Furthermore, I am using both sets of slotted holes in the skid plate. If you need to see something else send an e-mail to racinrudy@hotmail.com and I'll do for you what I can.
Lastly, my 360 is pretty motivated (Rv Cam, Edlebrock intake, MSD ignition) and I thrash on my 176 w/ no trouble (yet). 3.31 gears and 33" tires. It will get sideways on pavement!
Yes, there are tougher trannys out there (I have my NV4500 in the corner of my garage) but you aren't wasting your time w/ yours...it was Jeep's V8 transmission in some applications.
Take care,
Rudy
I'm with Rudy. I've seen some pretty strong jeeps running T-176's, successfully. Mine's been good for quite a while, behind a 258. I keep waiting for it to break so I can use the NV4500 that I have sitting, too.
Paul
