No new pictures still looks like above, but have made progress on the wiring issues. Found my drain to the battery. I had wired the TCC relay to always on circuit so it pulled power constantly, got it moved to a key on circuit and the drain went away. Also found that the battery ground cables were not ground well. I had put them on a bolt in the manifold and that was not working well. So they are getting moved back to the block. A little harder to hook up but should work better. Battery has not gone down now for a week of sitting hooked up. Dash light issue was a bad lighting inverter/harness from Speedhut. Gave them a call, they sent me a new one no charge even though it has been a few years sense I bought all that stuff. I received and broke the wiring tab to the dimmer control trying to get the knob off to mount it. Called purchased another one, have to be more careful getting the knob off this time. Actually had to use a screw drive to pry the knob off the one I broke. So now I will start with that and be more careful how I hold it.
