Spankrjs 1985 Spring Special CJ-7
I went ahead and set the engine at TDC #1, just in case I need to swap in the new timing chain set. It got disturbed later on removing the harmonic balancer.
Balancer at TDC:
Distributor at TDC:
I pulled all six spark plugs out, again, to enable hand cranking the engine over to TDC everything. The plugs are still looking odd. I am assuming the side facing the valves is getting dirty, the other side stays clean. These plugs only have about 50 miles on them.
Dirty side:
Clean side:
All plugs 1-6, left to right. Will continue to monitor.
More parts out of the way:
And of course, the bolt threading into the crank that secures the harmonic balancer did not want to budge. Note the odd chunk missing off the face of the harmonic balancer.
Thank God for the Hot Rod, saved my butt, again. I had the same issue with my red Scrambler last year. This bolt was worse. I borrowed this tool last year, bought one shortly after, life saver.
Wrap the electrode around the bolt head, push down the button, held it there about 5 minutes, impact took the bolt out. I prefer this to a torch, less collateral damage.
Removing the harmonic balancer with a special puller.
Oil leakage is evident.
Pretty bad groove in the balancer hub. The timing chain seal kit comes with a Speedisleeve for the hub, but me thinks this groove is gonna need some redneck engineering.
I noted this earlier, not damaged, looks machined this way, maybe when the engine was originally built/balanced at the factory?
Timing chain cover bolt location reference picture for me.
Timing cover bolts removed, including the lower oil pan bolts.
The timing chain cover did not want to come off. I'll wait until I get the oil pan off and see what's going on with it.
Reference pictures for me, under engine brace.
Driver side attaching point:
Passenger side attaching point:
Most of the oil pan bolts removed.
Three of the four corner, larger bolts, loosened. Will have to remove the lower bellhousing inspection plate to get to the last bolt, note the little tang from the inspection cover blocking bolt head access.
One or two bolts left on passenger side, blocked by the motor mount assembly. Will have to jack up motor, remove mount, to get to the bolt.
Just a little more disassembly work, then hours of cleaning and scraping, that's it for now.
