- Biloxi
- MS
Also of note - I was having the idle speed vary, too high sometimes. Come to find out, the throttle return spring on the throttle body was NOT closing the throttle all the way at idle. I added an old clutch return spring as a secondary throttle return spring, works perfect now.
I have this issue with my Red Scrambler sometimes, too. I always assumed it was an IAC issue, but I will add a secondary spring to the throttle like I did on my Green Scrambler.
I thought this was kind of "Redneck Ray", but factory 4.0 YJ's and Cherokees came with a secondary throttle return spring, just like what I installed. Pretty sure my 05 LJ does NOT have a secondary return spring.
The secondary throttle spring also makes the pedal a hair stiffer, which helps smooth out the "jerky/responsiveness" at low speeds I had before.
