Do your "switch labels" that light up (like the ones for the HVAC) bleed light out the back side? My labels bleed so much light on the back side of my dash it's almost like having a floor light on all the time. I'm thinking bout painting the back side of each one black to trap the light in.
and need to source a replacement of some flavor.
BTW, I asked them about lighting the hands on the clock and they said it's simply too hard to light both hands stacked on top of one another like they are.![]()
Wait, so the clock is useless at night?
In a manner of speaking, yes. When your dash lights are on, the face is lit but the hands are not.
Maybe they could at least put some luminous paint on them?
Bigwalton,
Okay, so a small project of wiring the KC lights has expanded to doing it right and adding accessory fuse panels similar to yours. I'm trying to decide what goes on battery power and what goes on ignition power so I can size them correctly. As I always think #WWBWD (we're trending again) I referred back to this thread and I see that it looks like you have a wire labeled "voltm" with battery power. Does that mean that your SpeedHut voltmeter is constantly displaying your battery voltage?
BW,
When you wired up your Speedhut gauges, what source did you connect to the "+12 volts keyed ignition (red wire)" and the "+12 volts dash lighting (white wire)"?
Also, did you use the same source for the for the white wire above with the white wire input to the inverter (+12 volts dash lighting)?
My first time ever wiring a vehicle was recently when I installed a Painless harness in my Scrambler so I'm not well versed electrically.
