I can set it to what ever RPM i want. Anyone who has seen me drive knows I dont drive with MPG in mind.
Currently its set to 5500.
I didnt need one, but for $20 i couldnt resist!!
Hope to get back out tonight. GPS antenna mounted and connected, hidden in fresh air vent like that damn Canadian's. I'm also getting signal in my garage
Started in on the switch plate wiring. Have a lot of wiring clean up to do. And have to actually fab the switch plate.
Pics to come, not showing up on this thing for some reason.
Yeah, I really like that placement and did the same though I had to drill a hole for my wire where Mike apparently had a gap somewhere he could use.
After I got ALL the honking long wire secured under the dash I came back and put some RTV on the opening in the rubber grommet to seal it back. Mounted with emblem tape after cleaning the plastic.
Plugging away at the switch plate wiring. Some more connections to the new love of my life, this distribution block is the schiznit. I have the two existing switched circuits (OBA and KC lights ready to plug in. Cleaned up more wiring in the engine bay and moved two circuits off straight battery connections to the PDC.
I love it when a plan (finally starts) comes (coming) together. Been needing to do this since the engine swap.
