Spray Liners? The good, the bad, and the ugly?
I used Line-X and would do it again. I even put it on my top, roll-bar, top part of the doors, and fender flares. I guess I got carried away, but I like the look and don't have to worry about messing up things.
I used Ultimate linings on my son's and hope to on mine if I can ever afford it, it has held up very well for abour 6-8 years except where his master cyllinder leaked, brake fluid will destroy it. It is a 2 part urethane that mixes in the gun and cures almost instantly. I too stripped the jeep completely before taking it down. I used a different vendor using the same materials on my daughter's Scout, a lot of bubbling where I had applied POR 15, not sure if that was a prep issue or an interference issue. I used them because they were closer and cheaper, big mistake, fortunately they are now gone The first place is thriving though and, as i menioned, I hope to ge tmine in sometime
I have Line-X in my jeep and Rhino in the wife's jeep. I prefer the Rhino since it can be applied much thicker at around 1/4" thick. The Line-X is around a 1/16th.
The Rhino allows for some additional heat and sound protection. It really helped tone down the sound of the flowmaster muffler on the interior.
my .02
when I did my resto mod on the first scrambler I just used herculiner and did the underside of the body and the inside as well. It looked ok but a while but faded pretty quick and really wasn't that thick. All depends on what you want but any of the do it yourself kits are really going to be fairly limited on how thick you can get it on.
I've seen several local jeeps that have been linex and they looked fair. They all fade no matter what anyone says. The rhino seems to be much harder/courser after its all said and done though.
A while back I traded a guy some GR8TOPS half hardtops for some commercial grade spray in liner equipment that he had barely used. I just haven't had time to get it up and running yet. Its a pretty cool system and the material itself is very rubbery but pretty durable.
Its called Reflex Linings.
http://www.langeman.com/Reflex/?gad...=standard&OVADID=1251205022&OVKWID=9829216022
The cool thing about this brand and machine is you can do colors in it by simply adding the automotive tint to the machine. Get the color code off the vehicle, go to the automotive paint shop and buy just the color tint. Then add the tint to the machine, flush the color line (NOT THE WHOLE machine) and you can spray to match the vehicle. No waste by having to mix the whole bucket of spray and no guessing the color match.
I've seen it on their vehicles but haven't had a chance to spray my jeeps yet. But, when I do, I'll give another post. Once I get it up and running, anyone near me come on down and well give it a try. I've got about 50 gallons of material to use up.
matt
I shopped around for the best looking and most durable spray for the truck bed and finally went to Cap City in Virginia Beach and had my '08 Silverado sprayed with Full Metal Jacket. It cost $450 and looks great. Whenever I get around to peeling off the jacked up Rhino job in my Scrambler, I'll have it sprayed with the Full Metal Jacket as well.
bedliners
This may be retarded??????? Has anyone built a redwood bed in a scrambler like the old pick-ups?? just a thought
Not retarded, unless I am too! Before I lost my mind and hacked the bed off my Scrambler, I thought about replacing the floor with oak and aluminum. I would, had I it to do over again, rather than cut the bed off. That was just plain dumb. I like the look of the old truck beds, but they don't wear like steel, and they're harder to keep looking nice when you're slogging it thru mud all the time.
Howdey. Just wandering what kind a prep work you did befor you got the Rhino? so one said that you have to sandblast the entire bucket.
If you're planning on doing a "wood" bed, try using one of the newer composites, like Trex (lower end and easily available at places like Home Depot), or TimberTech (more expensive but much more realistic looking). They'll hold up much better than wood in the hostile environment a Jeep sees.
The bed of my Retro Wrangler is TimberTech "Tropical Teak":
I've done Herculiner in a couple of vehicles, the bed of my truck (which gets used as a truck), and the interior of our 2004 Rubicon.
I would not use this product in a truck bed again, it gouges way to easy, very painfull on the knees and hands, I ended up reinstalling the plastic bed liner over the Herc. I may try the power washer removal method and then go with Linex.
I would use it as an interior liner again though. It has held up extremely well in the Rubi. Neither of us drive barfoot so no worries there. Someone mentioned paying $550.00 to have their interior lined proffesionally, I'm into the Herculiner for less than $100.00 and about 8 hours time.
I am doing a frame off and just had the entire underside and firewall done on the outside and the inside end to end to the firewall done with VORTEX liner. It is an epoxy vise urethane base. It came out great and sealed some swiss cheese sections after it was blasted. Now the metal is filled and reinforced with a commercial grade epoxy. Stuff may chip or scrape but won't break or rot....ever. My guy in Chesapeake garuntees the work for a lifetime! Total cost $750.
I just sprayed a bedliner in with a modified shutz gun and a sem bedliner product. There is a soft and a harder more plastic product. I chose the harder and am pleased with the results. It may be a too textured for some, but that is what I wanted and you could control the look. The cost was around $200 for the bedliner kit and then the cost of the expoxy primer.
Herculiner spray in
I used Herculiner on mine, a gallon and a quart ($125) gave me three good coats over the rail. I think it works best if sprayed on using a cheap ebay style undercoating gun ($25). I thinned the mix a bit with Xylene and it sprays well. Prep as has been mentioned is key.
Here are some photos of the effort and result. After spraying you can overcoat with UV protectant to slow fading.
I was going to do mine with the sems product ,but today i saw one by scorpion liner the sems that I have seen eventually crack. This scorpion is not supposed to crack.
I had a Rhino type liner in my '81 Scrambler. I cut into it with a razor knife and then got under it with a pry bar. For the most part, it peeled right up. It helped to have one person working the pry bar and another pulling.
We spray Reflex at our shop. It's like rhino as far as the rubbery feel and thickness. I have it sprayed in my CJ7. I even did Racing stripes up the hood with it.
Someone mentioned the texture of linex having a better, more uniform look. If applied correctly, the texture of Reflex and Linex can't be distinguished. It took me a year or two to get the technique just right. It all has to do with atomization and taking a bit longer with your texture coats.
We looked at a lot of bedliners before we bought the Reflex system (keep in mind, this was almost 5 years ago). Rhino looks ashy after a few years because the urathane has no UV protection. Linex looks good but is just too damn hard on your skin. Quickliner is cheap crap. Superior liner is way to thin and take 24 hours to dry.
These are my opinions, as someone said previously, go and look at what's out there and decide what looks best to you.
Also I wanted to add, we removeold bedliners with what's called an Inductor. It's basicly a high powered magnet that heats up the metal underneath the liner. You have to know what you're doing though because it can remove the paint and primer from both sides of the metal too (top and bottom). We use it mainle to take off door moldings and nameplates. It's also nice for removing windshields and back glasses without the needfor a knife.
Do any of these products provide any isolation against heat coming up through the floor from the cat and muffler? Seen any difference in cab temperatures from before and after application?
Just had my Scramblers interior srayed with Linex. They did a great job and it came out awesome.
The only issue I have is when I dropped it off in the AM I showed the guy where the original info decal was, inside next to the drivers seat on the inner rocker (I had stuck a piece of green painters tape on it). I told him "DO NOT SPRAY HERE"
They sprayed right over it.
He tells me he can get a replacement decal. My question to him..."Where will I put it?"
Any ideas?
I'll get pics up over the weekend.
