Is it leaking at the rear (rear brake line screws into a adapter fitting) or the front button. If either the o-ring seals are leaking. Been told it can be fixed but the process of taking apart and putting together tears the o-ring. If this is your problem, contact inline tube. Finding a new valve that doesn't leak is hit or miss. If it's leaking where the hard line flare/nut connects to another fitting/line check to make sure the flare has no nicks or a burr. Is so sand smooth and put together. Us brake fluid to lubricate the treads. Because stainless is harder than steel or copper you may have to use more pressure when tightening to get the surface's to compress together to seal.
