Steering box bracket
jeepnjon
Member
Cumming
GA
For starters, my 81 Scrambler has a 2.5" suspension lift along with a 3/4" shackle lift. My 76 CJ5 has a 3/4" shackle lift with what I believe are stock springs.
I ran across two of the M.O.R.E. power steering box brackets for sale for a pretty good deal so I bought both of them with the intent on installing them on both Jeeps. Come to find out, these are the version that move the steering box 1.25" forward from the stock location.
My question is, can these brackets be used on my Jeeps as they're currently setup or will I have clearance issues with steering components? I know these are designed for use with shackle reversals or other scenarios where the front axle is moved forward but hoping I can use these and not have to try to offload them to recoup my money.
Edit to also add that I'd rather not go through trying to install if there's zero chance of it working. This job is a pain and I don't want to do it twice!
jeepnjon,
You should probably be OK. The only problem I can think of would be the length of the steering shaft. They do telescope and can be extended to take up the gap. Do you run a body lift on either Jeep? If not, you should be fine. It's also possible that you can close some of the gap by adjusting your steering column so that it mounts more forward. You won't get much here, if any, but I'd push it forward as far as you can and then make up for the rest by extending the shaft.
jeepnjon,
Thanks for the reply RockTractor. I agree that I should be able to use the slip in the steering shaft to reach the new box location. No body lift on either Jeep.
Update - the instructions reference the standard box mount but the part number on the packaging reference the relocation mount. I've emailed pics to MORE to confirm which brackets I have. Fingers crossed they're the standard mounts.
The issues that you will run into using them is that you will have to notch the back of the front crossmember and it will place the hose connections to the steering box under the radiator. Both are a pain in the a$$. Sorry.
I used Pure Choice Motorsports banjo fittings for power steering when I used the MORE +1.25 mount. You still have to relieve the area above the fittings but not too much. I still dropped a bent rod in the channel and welded it up. But that beats hacking Scrambler huge notch in there. Pics in my build thread.
Had a heck of a time finding them in my thread, so here’s the only pics I could find- they’re before relieving the cross member. C1C99052-56FB-45DE-BC42-B0112B130807.jpeg1A12252A-7B9C-4F2A-872E-8E4A0A022175.jpeg
Honestly, the fittings I pictured are cool but if you don't need them, don't bother. Why introduce another spot for a potential leak down the road? You did get lucky!
