streched scrambler build ideas
cj-8+
Lake St. Louis
MO
Well no one wants to buy scrambler in parts so I guess I am going to have to finish it (thats what I'm telling wife) I am working on going back to spring under with 2.5 in lift wrangler springs 1.5 in shackle lift and 1in body lift topped off with poison spyder fenders up front and tj fender flares in back. I have fresh turbo 350 tranny adapted to dana 300, chevy aluminum radiator, chevy 350 4bolt main block that needs rebuilt. I was not happy with power from my last 350 motor on my last cj-7 project.
questions
1) will this be enough to run 35 in boggers?
2) what power plant combo to run (on a budget)
-I'm thinking find 99 chevy 1500 rust bucket and take motor tranny t-case wiring computer or 454 tbi and mate to turbo 350
Oh yeah...
I am building rig to cruise around town for fun and light off road. I want something I can mash throttle and burn rubbler. I love diesels but don't have budget for one other than 4bt but that isnt going to spin tires (on my budget). I am also open to other ideas than what I have mentioned
1) It will be really close with the 35's. Are you running the wide Boggers? I think they may hit. I run a 4in lift and 1in body. 35 x 12.5's clear fine on the street.
2) If you want to spin tires, you may need to get some 4.56 gears also. Weigh your options. If you do a nice rebuild on your 350, you can build a nice 350hp motor to tear around in. A 454 would be nice, but thats a big, heavy motor. The 350fi would be nice. I would look at your budget and see which one you could afford.
I have 4.10 gears and cant afford to swap them. I have seen running 454 tpi motors complete on craigslist for $1000 or less. I like less weight in 350 but since Jeep is so long I think 454 wont be so bad.
I have owned both small block and big block Chevs. With 4.10 gears. 350 with 700R4. Low, first gear with overdrive. Great offroad and street combination. :twocents:
Not gonna clear the fenders. Absolutely not if you have a shackle reversal. Maybe go with tube fenders up front. I have a BBC TBI in my jeep and cooling is the biggest issue I have had at low speeds(crawling and working it pretty hard). It is currently going through a re-resurrection and will be putting a taurus fan in place of my mechanical fan. Also a Mr G Hi flow h20 pump, engine ice, and an auxillary tranny cooler. Also been looking into the new MSD EFI setup, but a motor and harness can be bought for what they want for it. Obviously If you wnat to light em up, you will need some ponys under the hood and some gears to get it wound up.
I have tube fenders, be cool radiatior, and expensive electric fan. I also have turbo 350 tranny connected to dana 300. Will a stock 454 tbi "light" my 35 boggers up with that setup?
