Stuck and have a question on the ignition lock
tom keyes
1981 CJ-8
Louisville
co
Hello all, I have found myself stuck. Here is what’s going on. The lock on the tilt steering wont let me turn the Jeep on? Has anyone played with this thing before? I see a small metal rod that run down the side of the column and goes someplace? I can see everything is related to this metal rod moving to the right position I think??
Anyone have a clue on this? I was able to turn the ignition to access position and jumped the Jeep from the battery directly to the starter to at least get me off the road, but I don't want to do that every time I need to start the Jeep up... Any parts numbers to look for?
Thanks
TK
Metal Rod
The metal rod you speak about goes into a plastic piece with a bunch of wires that go into it. The rod moves a piece inside the platic piece. You should take it down it is not hard. Imagine a c on both sides that face each other and that plastic piece slides into them. Push up on the platic piece towards the top or so. You will see the rod will slip out of it. Oh yeah they have a small bolt that holds it in place. Only 1 on the front side that you can see. Bring that to the auto parts house and get it and put the new back on.
I ramble like Truck, but i hope you go the just of it.
Thanks for the tip on the Ignition switch side. Looks like my problems are with the Cylinder. I took some WD40 out and spryed the poop out of of where the key slides in. I was able to turn it a wee bit more. Then I just did the brute force turn with some pliers and was able to turn the jeep on and back off again like that. So now I will pickup a new key cylinder for under $20.00
Here is something to make you sick though. I called the local Jeep dealer and asked the parts department for a price on a new Key Cylinder. Everyone on the web and local part stares list them under $20.00 bucks. DC wants $79.00 for the thing. I ask the guy how they could charge that much and he just said the other stuff isn't a DC part... O my I didn't know DC parts were better then gold. Makes you wonder how these places stay in business????
Thanks again !!!
TK
Ignition lock broken -- is this a huge deal to replace
I know this post is quite a while ago .. but how big a deal is it to replace that cylinder?
1982 CJ8 -- tried to start it and heard a SNAP in the ignition column as I turned the key to the START position .. now the cylinder appears to work and go through all the positions .. but when the key is actually turned past the RUN position into the START position -- that would usually engage the starter -- nothing happens. Key goes all the way to START and when released returns to the RUN position .. but starter does not engage.
Any suggestions??
Thanks .. Mike
Thanks again !!!
TK
Check and make sure the rod on the left side is moving when the key is moved. . If not, it's in the upper column. If it is, it's in the ignition switch mounted halfway down the column. If it's in the upper column it could be a broken cylinder tip, the rack could have broken (common) or the gear could have come off the pin that engages the cylinder.
