Sway bar or no sway bar that is the question...
johnlt44
Chattanooga
tn
have a 1981 CJ8, 258 c.i.d., 4 speed SR4. Stock Dana 20 rear and Dana 30 front. I want to spring over axle using some YJ springs with a 3 ½ in arch. I know I will need new spring hangers and will have to move the front position. My question is about the spring plates if I use YJ spring plates there is no place for the sway bar to mount. Also do I need the sway bar? Any help would be appreciated. Thanks.
doing a spring over and lift springs will give you ALOT of lift. I'm running a spring over with 2.5" lift springs and no body with 37" tires.
as for the sway bar, I pulled mine out on my CJ-7 almost as soon as i got it back in 2000. I pulled it out of the CJ-8 as soon as i could too. I feel there really isnt a need for them in a leaf sprung Jeep. You shouldnt be cornering fast enough to warrant having one. The leaf springs are usually stiff enough and it minimizes alot of the body roll.
I have driven my old TJ with the sway bar disconnected. That was fun...:crazy: But I got used to it. The coils are way softer than leaf springs.
all i can suggest is drive around with it... then disconnect it and drive around and see if you notice a difference. If youre fine with it, pull it off entirely.
all that being said... most places have the law that if it came with it from the factory it must remain on the vehicle. (make sure the frame brackets are removed, so it was "never equipped" with a sway bar from the factory) ;)
note... HOLY CRAP!!! thats post 1000 for me!!! :crazy::crazy::crazy:
Go to an empty parking lot. Drive 15 mph in a straight line. Then, "avoid the moose"! Turn hard left and right hard. Now try it at 20 mph... and so on.
I did ^ that ^ in my 1988 Grand Wagoneer with 4" of lift and 33s. But, I did it at 25 mph for the first test. After the initial "left then right", the next 6 inputs were trying to keep the Jeep from rolling over. Lest you think I can't drive - not a pro, but have driven my RX8 around Road Atlanta at 120 mph (okay sure, pro would've done it at 145 mph... but you get the point). It scared the #*$& out of me and the sway bar went right back on.
And ya have to assume the 8 is less stable than the GW
Thanks
Still a work in progress, winter is upon us and I dont have a shop. I do thank you guys for the input.
I would never do that much lift on stock axles, no matter how you do the lift. Too narrow even with the swaybar. You'll also be WAY over the limit on tire size for those axles if you match up the tire to make the lift look "right".
I don't use a swaybar, and do get body roll on the street. To Manhattan's point, I consciously think about the fact that I'm going to hit the moose, not avoid it, when I drive. There's a lot of deer around here and I literally think about this fact in certain stretches of road. IMHO you have to change your thinking when driving a lifted Jeep. I have the same thinking when in my now-lifted LJ too. Part of the reason I put aftermarket bumpers on both.
I put this to the test when a woman pulled out in front of me a number of years ago when driving my Scrambler. I didn't oversteer trying to avoid her and hit her rather than going too hard and flipping. Ended up costing me a lot of rebuilding, but better than the alternative I think.
I drove a CJ-7 for almost a decade as a daily driver and honestly, I am a leadfoot and was a total idiot. I LOVED taking corners in my CJ which was occasionally on 2 wheels or too damn fast around an exit/entry ramp.
Long story short, I luckily did not kill anyone or myself, but I am sure glad I had my sway bar as it saved my *** on city streets. Of course, I never took it off road because I couldn't afford to fix it anymore than I had to already (every weekend). So, a sway bar never caused me anything but smiles and miles.
I agree with Manhattan, give it a try without it. You might find yourself scurrying back home to slap it back on, and there is no shame in that!
I have RE springs on my Jeep running without a sway bar and it turns like a Trophy truck with the body roll. I have since installed an Antirock and it's MUCH better handling than without. I was just saying that I wished that I put the bar on a long time ago-
I also have the RE Extreme springs, 4.5" lift, spring under, 35" tires, no sway bar. It leans like crazy! My wife thinks it's going to tip over...I'll probably be finding a way to retrofit an Antirock like mysunnshine.
I have 5"
Alcans SUA with soft Bilsteins, I do drive it most every day and dont have a problem with no sway bar, however, if/when I replace shocks I MAY got to an adjustable to reduce the body roll or, mor e likely, install a Currie anti rock at some point.
My suggestion is that if you drive conservatively then try the no sway bar and see what you think, carefully, if you drive more aggressively leave it on until you mellow.... Or do some adjustable shocks with an extra firm setting or do a Currie anti rock. If you do, take good notes and pictures and send them to me please....
