akadeutsch
New member
- New Prague
- MN
A 1981 CJ-8 Scrambler on a 2005 Wrangler LJ Rubicon Chassis
Project Summary
My idea brings together two of the most iconic long-wheelbase Jeeps ever built: the original 1981 CJ-8 Scrambler and the 2005 Wrangler Unlimited (LJ) Rubicon. The CJ-8 provides the 2 doors, the classic lines, proportions, and character that define early Jeep, while the LJ contributes the chassis, drivetrain, wiring harness, reliability, and the push button trail rig options that the Scrambler never had from the factory. The result is a vehicle that retains its vintage identity but Climbs, crawls, flexes, muds, drives, stops, cools, and performs like a modern Jeep. This is not a restomod for show; Ill be driving it.
Base Vehicles
The project begins with two complete vehicles:
Core Build Concept
The heart of the project is a full chassis and systems transplant. The CJ-8 body will be lowered onto the LJ Rubicon frame, using fabricated mounts built from 3/16-inch plate and spaced with a one-inch hockey-puck body lift. All factory LJ mechanical systems—fuel tank and evap, HVAC, brake booster and lines, steering, Rubicon locker pumps, electrical harness, drivetrain, and cooling system—will be retained and integrated cleanly into the CJ shell. With this approach I hope to preserve the reliability, serviceability, and drivability of the 2005 Rubicon while retaining the appearance and layout of the Scrambler.
Drivetrain Strategy
The 4.0L engine will remain stock during the initial build to keep cost and complexity low. Once the vehicle is complete and fully operational, the engine will eventually be replaced with a 4.6–4.7L stroker using the AMC 258 crankshaft from the original CJ engine. The transmission plan includes replacing the donor’s automatic with the NSG370 six-speed manual, supported by either a PCM reflash or a 2005–06 factory manual PCM. This keeps the drivetrain simple, durable, and parts-compatible with Jeep’s OBD-II ecosystem.
Electrical Integration
The 2005 LJ harness will be retained nearly intact. As far as I can tell only minor changes are required, including the clutch safety circuit, reverse-light connector, and neutral safety adaptation. The factory LJ cluster will be mounted discreetly within or behind the CJ dash, preserving a vintage look while retaining full diagnostic capability. All lighting and accessory wiring will be adapted through simple connector changes when necessary..
Budget and Philosophy
By fabricating mounts, performing all labor personally, and retaining stock LJ systems, the project can be completed for approximately $15,000 total, including the donor vehicle. Future upgrades—such as the stroker, suspension tuning, or paintwork—can be completed incrementally. The guiding philosophy is to build a capable, serviceable, long-life Scrambler that combines Jeep’s best vintage aesthetics with Jeep’s best modern engineering.
End State
When complete, this vehicle will look like a clean 1981 Scrambler, sit on a fully modern chassis, run a 4.0L (and later stroker) engine, operate with factory lockers, air conditioning, and OBD-II diagnostics, and drive like a 2005 Rubicon. The project delivers the long-wheelbase, reliable, coil-spring Scrambler the factory never built.
Project Summary
Base Vehicles
- A clean, nearly rust-free complete running and driving 1981 CJ-8 Scrambler with running 258 and aging axles.
- A fully functional 2005 Wrangler Unlimited Rubicon clean and rust free donor, chosen for its identical 103.5-inch wheelbase, boxed coil-spring chassis, Rubicon Dana 44 axles, 4.0L engine, modern HVAC, OBD-II electronics, and availability of the NSG370 six-speed manual.
Core Build Concept
Drivetrain Strategy
End State
