The planning begins...
crakmonckey
Stroudsburg
Hello to the board. I have a 1984 CJ8 that is down to a rolling chassis after A LOT of internal debate. Anyway it seems like now is a good time to start planning all of the work that needs to be done to get this beast rolling again. I have had the 8 for 5 years and have been slowly working on little things that just keep getting bigger...
Current set-up: Nuttered 258 with MC2100, T17X, AMC 20 (open 2.73), Dana 30 (open 2.73), 33x12.5 tires
The tires fit and it runs well enough, but I have never been happy with the gearing, so I think it is time to change some parts. I want to be able to drive the 8 whenever and wherever I want, so I understand the planning aspect is important.
The suspension seems like a good place to start. I know many people on here like the Rubicon Express 4" lift. It does have many of the things I am looking for (greasable shackles, wider springs), but I was wondering if anyone has done an Old Man EMU 2.5" lift with 1" body lift? and compared to the RE 4"?
I went spring over with RE 1.5 lift and running 35's with 427 gears. I have 4:1 reduction in low end of t-case. Crawls very well and still maintains decent highway mileage. Was running this with a 4.0 with AX-15 and did fine. Swapped in a Hemi and 545RFE 5spd auto just because it was available and I couldn't resist. But seriously, the 4.0 did very well with that setup.
I have always started planning with asking myself:
"What do I want to be able to do with this 4x4?"
Follow that up with:
"What do I want out of this 4x4?"
Then:
"What does it need to get the jobe done"
and last:
"What bells and whistles do I want"
Make a list for each, if you have duplicates, those are the important ones to do. Then prioritize the list in order of importance and timing for when its easiest to get a particular job done.
Then you need to look at the timing, give yourself too little time and you'll fail, too much time and it will slip past and you fail again. Plan out what days your going to work on it and what you want to accomplish, and allow it to float, some items will look small, but be big time consumming items.
Now, for where your at, I'd be looking at your axles and frame first. is the frame solid? If not fix it, weak areas will show up on the trail fast.
Next you say your unhappy with the gearing. Tire size is generally the factor here.
So, ask yourself: What make you unhappy? the on road manners or the Off road Manners? You have two basic solutions depending on how you aswere the questions: Change the tire size or regear. Most people regear to run larger tires. there are different solutions depending on the axles you have.
If you need more gear on the road, regear the axles, if its offroad, regear the axles or t-case, or add a doubler. or a combination of that..
Welcome to the forum!! :wave:
Assuming I'm reading you right, you want a trail-capable DD (which is just what I wanted :D). That's a great thing to decide straight off, it means offroad ability can't kill highway driving.
I'd actually say that the engine and axles come before or right alongside the suspension decision and to me engine/axles are all about the questions asked above and what you really, honestly think the largest tire size will be that you want to run.
IMHO (and there's lots of Os out there!), 33s can work fine with the 258, 35s beg for an engine change if you want both strong highway and offroad performance because the compromise on either offroad or highway with axle gearing will just be too much on one end or the other. My compromise for good offroad performance going with 4.56 over 4.10 gears meant it was hurting to do 65 on the highway and had no power. This is why I went to a 4.0/AW4 (85 on the highway and all kinds of passing power :smokin:)
That decision will play into your axles. 33s on stock axles with one pieces in the rear can work, 35s are really pushing things (again, just my opinion). This is why I went to Waggy axles.
I wanted to run 35/37s, so I worked back from there through the axles to the tranny/engine and suspension.
Ultimately you can fry your brain trying to come at this planning from all kinds of angles (it's kinds fun though!) so pick a way to think about it and make a call and git er dun! :cheers:
I like the suggestions, really I do. I'm glad to see that there are people willing to help with the planning stages. I do want a vehicle that can be a DD and hit the trails, but there are so many types of trails...
I don't need to drive the 8 every day, I have a VW Jetta when I need comfortable long drives. I want to know the 8 can sit for a week or two if necessary, but be reliable to take wherever I want to go...Scrambler Convention, deep woods camping and fishing, and go in the snow when necessary in NE PA. I loved my old 90 YJ in the snow.
So, I think the max tire size is 33, currently 33x12.5, definitely don't want bigger. I am pretty convinced that 4.10 or 4.56 is the way to go on axle gearing. I am confident I can make it through a gear swap and and upgrade on both axles. I don't want to go through the hassle of cutting axle tubes if I can make the current axles work. Once I decide on gears, I will start looking for used stuff in the right "ballpark". I started looking at pricing new carriers and decided ARB may be worth the cost for winter driving and not having a locked differential on the vehicle unless necessary (other lockers worry me) and I do get caught driving in surprise snow storms quite a bit.
Honestly, the engine and tranny is the hardest decision for me. I want a manual transmission, this is my sticking point deciding what is the best fit for DD and capable rig. I am leaning towards the NV4500 to keep the engine rpm lower at highway speed (70-75). I think the cost has come down some from when the tranny first came out.
The engine is whatever I need to drive the other choices. I like the 258, I just don't think MPI is worth the 2k for it. I haven't seen any real data on a 4.0 head swap nor do I think a stroker is justified. An AMC V8 would be acceptable as well.
The frame looks solid as a rolling chassis. I will probably strip every darn thing off at this point to make sure it is as good as it looks. There are a few minor problems that I can fix on the frame (mostly body mount points and the rear crossmember (pooling of water from the old rear bumper), nothing that welding won't fix. I will decide when the time gets closer whether the frame should be dipped or just POR'd.
Well that is enough babbling for now.
I think the hardest decision to make is the drivetrain.
You want to run a NV4500, Good choice. :thumbsup: That makes the rest of the drivetrain is easy:
Dont bother running your AMC 258, the adpaters alone from Advance Adaper or NV4500.com start around $900 and go over $1200! :eek:
Your money is better spent in other places.
Unless you already have an NV4500, Look for a Chevy model from behind a 350 V8. You dont 'Need' a 4x4 trans. you can use a 2wd trans with an adapter to convert it to 4x4 from Advance Adapter, (or build it up from Dodge Factory parts, but the Advance kit ends up cheaper unless you have a Dodge doner trans) You will still NEED a T-case adapter either way, so overall, the 2wd trans may end up the better deal.
Swap in a Chevy 350 V8, the Chevy version NV4500 and Dana 300 t-case. In the end, you will have the power to run larger tires on the highway, reliabilty, and parts availability and I am told the length is the same as the stock drivetrain, I'll find that out soon enough as I complete my swap.
The stock axles will be fine with 33" tires, but weld the tubes on the AMC20 axle at the housing, and be sure to run 1 piece axle shafts as well. The AMC20 axle is as strong as the D44 when this is done.
For suspension, you have two basic choices: Spring Under Axle (SPUA) and Spring Over Axle (SPOA).
SPUA is the stock setup, and 4" lift springs will be plety for 33's. the advantage here is availability of kits, less problems with spring wrap, and longevity.
SPOA: the process here is weld new perches opposite the factory ones, and bolt the stock spring on. You will get more articulation, but more body roll as well. you will have problems with spring warp and springs wear out faster.
Both meathods require some sort of steering correction solution, longer brake lines and perhaps longer driveshafts.
You mentioned running a spring lift/body lift combo. This is a good comprimise in cost as you can probably get by not having to lengthen your driveshafts. You may also get away with a small drop pitman arm as well instead of a more sophisticated/expensive steering solution.
I would not go above 1" with the body lift, too much stress is placed on the the body mounts when you start getting higher than that.
Check out NV4500.com for more information on where to source your transmison from, as well as Novak for tech.
Hope that helps you, good luck :cheers:
Orionn
I need to add this:
The Dodge Gasoline NV4500 came with a tailstock that has a 6 on 6" bolt pattern and a 23 spline output shaft, with abount 3/4" of protrusion....Perfect to mount a D300 to.
These are the 'Dodge' Parts I was speaking of in the post above.
If you swap these onto the Chevy transmison, you wont need any adpaters at all.
NOTE...While you can do this, but you may need to swap other parts as well from the Dodge transmision to the Chevy (countershaft). You may loose the low first gear and end up with the 5.??:1 first instead. I have looked into it, but I stoped due to pricing of parts from the dealer. I say "May loose the lower gears", I am not convinced myself as the ouput shaft is indipendant of the input, but needs to mate to the countershaft, and thats where the grey area comes in as I do not know for certain that the mating gears are removeable from either of the shafts in question. I did not persue it farther due to cost and I decided that its cheaper for me in the long run to just buy the Advance adpater kit rather than spend money and time just to end up with something I dont want.
I WANT 6.34:1 gear for first.
Also, you may be thinking that 'Why dont you get the Dodge transmisin and swap the Chevy bellhousing onto it'?
Well, you could do that, but you DEFINATLY loose the 6.34:1 first gear becouse you have to swap the input shaft as well and need to use the post '94 parts. That means no in my book, but could be good for you as the Dodge trans is more often cheaper than the Chevy.
After 1994, New Venture made both the Chevy and Dodge transmisions with the same gear ratios across the board, Dodge never got the ultra-low 6.34:1 gears, only chevy. If you want the low gear, you need to buy a '92-'94 Chevy transmision.
Hope that clears a few thing up.
Confusing, I know :crazy:
BTW.....As for DD the Jeep and hitting the trails, I suspect with that trans option, the engine swap and the stock axles and gears with 33" tires, you will find that with a well picked line on obsticles, you will be able to do all but the most depanding of trails..(ie. HEAVEY Rock Crawling of the kind you find out west). I suspect that you could wheel most anywhere east of the Mississippi with only minor issues.
Face it, the axles will be the ONLY weak link at this point, oh, and the wimpy U-joints. :banghead:
If you find yourself in alot of off camber situations, go with a wider axle, and more negative offset in the rims so you can adjust the track width to help stabilize the jeep.
Using full width axles gives you strength, and the negative offset brings the track width back in but wider than stock.
:popcorn:
Myself, I will be running a 1979 Ford FF D60 rear, shaved, with disk brakes, 4.56 gears and a spool with 35" MTr's (yes I will be DD it)
And in front a 1977 Jeep J20 3/4 ton front D44 with a selectable locker and OTT Hydro assist steering.
Ask question if you have any. :wave:
Orionn
Good info and details to research before the final decision is made for sure. The body lift I have is 1", purchased to replace all the old stock rubber mounts and be able to clean mud off the frame rails and all the other hard to reach areas. I think the 1" BL is more than sufficient, I wouldn't mind a 1/2", honestly.
The SOA vs SUA debate will never end. I see no reason to go SOA with a 4" suspension lift and 33" tires, so I haven't even considered SOA.
I need to look more into SBC350 conversions. I have never really considered placing a none AMC/Chrysler engine into the 8 before. Not that I think it ultimately matters, I have always had a Jeep inline six from 1994 until now and been pleased with them.
Orionn has made some great points and suggestions. As for lift and tire size, I have been running 33" tires on a 77 CJ 5 for years with a 2 1/2" spring under lift and 1" body lift with only minimal rubbing when really crossed up, so that combination should work well for you. I plan on running 35's with a 4 1/2" RE lift and 1" body lift on my CJ 8, As far as axles go, before I spent a lot of money building the front Dana 30 and rear AMC 20, I would give some thought to some Dana 44's. Either a Wagoneer or Isuzu Rodeo(Honda Passport) in the rear, and a Wagoneer in the front. These axles can usually be picked up fairly cheap and the build cost will be very close to what you would put into the stock axles. Plus sthey will give you a slightly wider stance. Just a thought.
Look into the NV3550/NV3500 transmissions. Not quite as low a 1st gear, but a lot lighter and easy to shift. Highly recommended by Novak. Sturdy enough for a V8.
I agree, the NV3500/NV3550 series of transmsions ia a popular upgrade transmsion for Jeeps and other 4wd trucks as they hold up well behind most small V8's and smaller engines.
Price of these transmisions is quite high due to the demand for them. IIRC, they were the Stock Jeep 5spd transmision from 2000 - 2004. They are also the stock transmision in the Dodge and Chevy LIGHT DUTY trucks, including the Dodge Ram 1500/2500 LD, Dodge Dakota V8, GM C/K models w/4300 Vortec, S series and Sierra LD trucks. there may be others, I am not well versed in Dodge and GM products.
They are rated for 300 ft/lbs of torque, have a GVW of 7200# and wiegh in at 110# with oil.
It has the following gears:
NV3550/3500 Wide Ratio trans, (code MG5)
First Gear 4.01
Second Gear 2.33
Third Gear 1.40
Fourth Gear 1.00
Fifth Gear 0.73
Reverse 3.57
NV3500 close ratio trans, (code M50, Some Chevy and Dodge applications)
First Gear 3.49
Second Gear 2.16
Third Gear 1.40
Fourth Gear 1.00
Fifth Gear 0.73
Reverse 3.57
The big bonus is the Jeep NV3550 shouldl bolt to your 258 I6 engine and the D300, though the t-case will be clocked down about 9*, so you would need to redrill the holes on the transmision or use a thin clocking ring.
If you decide to go this route, BE SURE YOU BUY A GOOD ONE! these transmisions require several special tools to rebuild and the cost of laybor and parts is much higher than most other transmiosions in this class.
Alos note, Like the NV4500 it uses Special Oil, if you use anything else you WILL kill the transmision.
Here in Michigan, alot of people started swapng the NV3550 into thier Jeeps as an upgrade to thier tired AX-15's. Most were happy, some wish they had gone to the NV4500.
In your case, you will probably be happy with it, especially for the ease of installation. It should give you what you need for a DD and for offroading as well.
Another bonus is this trans 'should' not require any body lift or tunnle mods like the NV4500 does.
There you go another wrench thrown into the gears (so to speak) !!!
Decisions decisions........:banghead:
Myself, I am sticking to the NV4500, for better ot worse. I want the lower first gear, and unquestionable strength. After the swap, I have a vacation planned for Moab, and other places, so I want to be mostly worry free so that I can complete the whole trip without driveline failures.
Good luck :cheers:
I was contemplating the NV3550 as well. The wide ratio seems like it would be nice. I just don't want an old truck transmission that requires double-clutching and a super long throw...as robust as they maybe.
If the NV3550 can pull the jeep at 75 mph behind a six(with 33" tires running 4.10 gears), then I would consider it. If it is going to be topped out at 65mph, then it would probably frustrate me beyond belief.
I just got off the phone with my friend that went frame off on his Acura NSX. He said everything he didn't do when the frame was bare that he has gone back to do has been very frustrating to know how much easier it would have been.
I am trying to avoid that exact situation. That is why I am posting on the Scrambler forum BEFORE I buy the parts...
How it will drive will depend alot on the condition of the engine. If its tired, no matter what you do it will still be tired untill you rebuild or replace it.
Lets look at drivability from a gearing perspective:
:popcorn:
Moving to 33" tires from the stock size (assuming 27" tall stock tires) will give you an efective raitio of 3.35:1 (thats what your 4.10 gears become)
So plug that ratio into the formula for RPM and you end up turning about 1800 rpm with those tires and gears (I would have really like to see the RPM come in around 2200 rpm, perhaps 4.30 gears in the axles?)
The 258 I6 puts out 115 HP at 3200 rpm, and 210 ft/lbs of torque at 2000 rpm, that puts max torque ~200 rpm higher than the math indicatess your engine will be running.
And max HP ~1400 rpm higher.
Assuming the engine is in good repair, I suspect that you will not have a problem running down the highway at 70mph with the 33" tires and the NV3550.
The same will hold true if you use the NV4500, even though it does use a bit more HP to opperate.
After looking at it from this perspective, I see it really comming down to a choice of Money, Relibility, and Availability.
The money; only you can decide what its worth.
Reliability I think is moot, we all know the track history of the NV3550 and NV4500 transmisions.
So it really comes down to Availability if your trying to souce transmision locally.
(unless you want to spend big $$$ and buy new from one of the many suppliers).
So now comes the legwork, calling scrapyards and parts suppliers and adding up the costs.
The more informed you are the better your decision will be on your futre drivetrain.
Good luck
:cheers:
Well I began pricing the dream. It was painful...hahahahahahah. The joke is on me. Rather then go balls to the wall I will probably still do this in stages.
Stage 1: Frame work
Stage 2: Axles and Suspension
Stage 3: Engine and Tranny
Making sure I don't do double work and prep items for coming items while the frame is accessible. This addiction hurts my head, but it has finally taken over.
A lot of info has been passed your way. If I might add one more bit of information to the equation, which will be later in your build. I read that you experience some "surprise snow storms" which is all too familiar with where I live. I have had different lockers in the past and the one I WON'T do again is the Detroit locker. When that baby slams locked in the snow you're in for the "E ticket" ride. Absolutely no control. I went with ARB air lockers and love them. Friends have the E-locker and I like those as well. I'm suggesting a locker you can engage yourself and have more control.
I am quite thankful for the wealth of knowledge that has been passed my way. The free exchange of ideas is one of the things that makes this forum great.
