A lot of the trailer strength for 5th wheel relies upon the structure to provide some support so it doesn't support100% of the camper body. If you remove the rear portion of the camper, you can't just add that much weight back onto the trailer safely.
However, if you are getting an older camper, their frames are a lot heavier and may be strong enough to do the job assuming you are cutting enough of the camper off to place the front wheels of the jeep over the axle. You would need an engneer to run the numbers.
What would be a better alternative and easier to do would be to buy a gooseneck equipment trailer and then add a pickup or pop-up camper on the front. This has been done by numerous folks. If you get a pickup camper that is only 8-6" and designed for a long bed truck, you should find the bottom is completely flat and can be set right on the deck. The gooseneck can be easily converted to a fifth wheel if you want to maintain the simplicity and ease of the fifth wheel connection.
I've calculated the weights and have found our family 18+5 trailer would have the right weight with the scrambler and a Lance 835 camper. This would be simpliest hook-up and go setup. However, I have weighed our trailer and found it to weight 5,000# versus a standard 16' tag along weighing only 2,000#. This convinced me weight wise, it would pay to run the pickup camper in the truck bed and use the 16' tag along.
