billyballer
New member
- Oakland
- CA
I'm gonna start by putting the rat on the table. I've got a CJ7 not a Scrambler. But this has been the best CJ related forum I've had the pleasure to read and most of my issues seem to crossover with the Scrambler crowd so I hope you'll forgive that, but understand if you feel the need to enforce CJ8 justice.
Jeep is a 1981 CJ7 with Scout Dana 44 front and rear, outboarded springs currently SUA with the RE 4.5 lift springs for CJ and 1 inch body lift. I bought this rig to replace my 1986 CJ7 which was stolen out of my driveway in 2020.
So I'm in the midst of trying to sort out the jeeps tracking issues. It goes down the road fine until about 40 mph it gets spooky and is hard to keep in a straight line.
I've checked and the scout 44 had not had the knuckles turned so I thought I'd start there. But while investigating I also noticed the welding on the outboard setup was pretty janky. I've got a decent welder and know how to burn so I could grind and reweld the setup, but I've also thought of just taking it off altogether and going back to stock spring mount locations. I'm not a hardcore wheeler or anything and will spend 90% driving this thing on highways. 33" tires is what is has and likely never go any bigger, and I do like the look of the standard CJ widetrack axles on 33s where I think the scout width starts to look a little out of proportion.
In the mean time I've scored both a Wagoneer passenger drop Dana 44 with good castor stock and a narrowed Scout dana 44 that is wide track CJ width with a cut and turn on the knuckles already done. I'm up to my ears in Dana 44s.
So I think it's probably more work to cut away and reweld original mounts but I have all the stuff to do it.
What do folks think. Leave them out board with 33s or put the mounts back to stock width and run the narrow axle.
Here's a pic of the booger welded outboard setup
