Tomken Rocker Knocker install
gmotox
Waterford
Mi
After starting athread asking for suggestions, I figured it would only be fair to show how I installed My rocker skids!
These are a used set I purchased from 'okjeep' off this site (top notch person to deal with)
First, I taped the body to prevent unwanted scratches, then I propped up Rocker skids and marked holes with center punch.
attachment.php
After drilling holes with pilot bit, I drilled to proper size with step drill and then painted holes to help control corrosion.
attachment.php
I used an ice and watershield type rubber to seal back of sliders. It is about 5" wide and is tacky rubber, this is the type you put around windows. I stuck it to the back of Sliders as the body side has no adhesive so I don't have to worry about the paint in the future!
attachment.php
Now it is time to bolt the Rock Sliders on, I used 3/8" black oxide allen head bolts that I previously painted flat black. I used a stainless A/N washer on exterior and flat washer on interior that got painted flat black after install.
Now time for the caulking, this is a trick I learned when I started remodeling homes for making nice thin caulk lines. first I taped the slider surface and then applied tape about 1/8" or less on the body above the slider, then after running thin bead of black silicone, I lightly wet my finger and ran it along the caulk joint. This creates a very nice tight caulk line. This is a good tip for many uses!!
attachment.php
And here is the finished caulk line, nice and straight!!
attachment.php
Looks great. Good tip on applying caulk. Keep us informed on how the backing you used holds up.
I hope I never have to remove these, but if I do I will inform on the backing!
