Torque Wrench question
Raven
Glen Rose
tx
I'm no true mechanic as I'm sure this post will attest to (just a weekend warrior). I am bout to install the Aussie Lockers on my front axle. I noticed on the instructions that they say to be sure & torque certain blots to 80ft lbs etc.
How important is it that these be tightened to the exact ft lbs? The reason I ask is I do not have a torque wrench. Is it absolutely necessary that I buy one? By the way I do not know anyone I could borrow one from either. Not trying to be cheap, just want to make sure it is necessary, and believe me this question is one more out of lack of experience than ignorance.
Thanks SC
Buy one...even a cheap Harbor Freight one will do. You'll find more uses for it eventually.
If you have a Kragen's or similar out there, you can rent it from them. You make a 'deposit' equal to the cost of the tool, then get your deposit back when you return the undamaged tool.....
For occasional use a cheap torque wrench does fine as long as you keep it in a spot it doesn't get banged around w/ Wouldn't be a bad idea to ask around some shops and see if they have a calibrator you can use, but that's not that big of a deal w/ automotive stuff.
You can get one for under $20. Others may be more accurate by 1-2 percent, but torqueing bolts is only about an 80% accurate way of tensioning fasteners anyway, so there's hardly a point in the extra money for very little real gain. It's much more important to make sure the threads are clean and dry as that's what most torque specs are based on. If they're supposed to be torqued lubricated the specs will say so and usually also specify the lubricant.
