tow capacity
mtbtreker
Did a quick search and couldn't find any info. Found lot's on vehicles to tow the jeep. What's the towing capacity of a 4cyl and 6cyl cj8?
thanks
Mtbtreker,
I'd like to know the answer to that question as well. I'm thinking about buying a travel trailer and would like to know how big of one I can safely tow.
Ask around at one of your local RV shops. The one I checked last week showed me one of "Their" sales advertisments, which gave a list of vehicles versas weight table. As I recall, it went something like this...
CJ/Wrangler - 2000 Max
Liberty - 4500 Max
Grand Cherokee - 6500 Max
Adding to that, I'm trying to factor in a few additional things. Not to say that this makes everything all better, but I figure they're worth taking into consideration.
- I run 6" of total lift & 35" tires (bad)
- I run wider axles (6") and am (3") longer than stock (good)
- I run larger brakes (good)
- I run a 300HP MPI/SBC (good)
- I run with about 500lbs of bumper/rockrails (good/bad)
- The list goes on...
Anyhow... All things taken into consideration, and not forgetting that I am still driving a SWB Jeep, I figure I can get away with towing a "Light Weight" trailer (3000-4000lbs) as long as I don't forget to exercise some good'ol fashion common sense.
21ft or 27ft - That is the question ??? Hope we hear more on this...
Thanx,
Jax
JEEPNJAX
I have spent alot of time towing a 21' travel trailer, weighing 4500 lbs wet. I was using a 98 Chev pickup, X-cab long bed, 3.73 gears, 350 and a trailer brake. It was not easy to tow, and there were many times I wish I had a bigger truck. I used a 4.0 Ranger several times just to move it around, too. It's not just the ability to get it to move, or even the ability to get it to stop ( a well adjusted trailer brake works miracles). It is the stability of the set-up. The trailer is a big wind-catcher. When semi's pass, the trailer will try to steer the tow vehicle. Any gusts of wind want to sway the thing like crazy, you'll wish you had a 8000 lb truck...downhill turns, bumps in the road at fwy speeds, anything that causes sway will give you a handful fast...and take all the pleasure out of a trip. I sold the trailer...hated the stress of towing. We camp now- in a tent or a motel:D . I am looking for a pop-up trailer, they have alot less wind resistance. I really think that is about all a 3500lb Jeep can handle.
Randyzzz,
Thanx for the input...
I agree with you whole-heartedly... Getting it moving and/or stopped won't be an issue for me. But as you say, keeping it straight behind me probably will. I've been looking at "High-Low" trailers as a means of having hard sides, without having all the big wind drag issues. Only problem is that they are typically real heavy. Maybe a "Pop-Up" might be the way to go, but I'd really like to steer away from rainy day setups...
Anyhow, I'm going to keep doing my homework before I do anything. That might include making the jump to a small Class "C" RV. Who knows...
Thanx for the words of experience...
Thanx,
Jax
JEEPNJAX
thanks for the input guys. I'll be towing a travel trailer as well. my f150 handles it with no big problems. I'll be traveling for work and have been considering ditching the f150 and towing with the jeep, or upgrade to a class c and tow the jeep. now where to put my bike?
Weird
I just looked through the 1983 Scrambler Catalog. I figured for sure It'd have the towing numbers -- nope. All it said was it has a 1,400 lb payload.
I bid on a 1983 Dealer Data Book a month ago. I know it's in there. Unfortunately it went for $65 -- too rich for my blood.
Anybody have an owner's manual out there? My guess is it's in there too.
Its not a cold hard figure, but, when I got out of the Army a couple years ago, I towed a Uhaul behind my Scrambler from Ft Hood Texas, to Wisconsin, then out to Delaware. (maybe 2500 miles) The uhaul had my Harley in it, along with a Bunch of other junk. Ive got a stock 6cyl, 31inch tires, T176, and the stock 2.72s in the axles. I had gone over the brakes with a fine tooth comb before we left, (along with everything else). Managed to make 70-75 mph indicated, and still got 14mpg on the flat highways (Ohio was all uphill, and PA was nothing but mountains-suffered a little there) I hit the scales in Texas with just the uhaul and hit them again in PA fully Loaded (The Army paid by weight, and you had to have your empty/full weights measured at opposite points) Turned out I was pulling a little over a full ton. 2,200 pounds or something. Not bad for the lousy gear ratio. The sales literature for the Unlimited lists max trailer wt as 3500 lbs, with 300 lbs tongue weight. and GCVW as 7800lbs, if that gets you in the ballpark.
