Its not a cold hard figure, but, when I got out of the Army a couple years ago, I towed a Uhaul behind my Scrambler from Ft Hood Texas, to Wisconsin, then out to Delaware. (maybe 2500 miles) The uhaul had my Harley in it, along with a Bunch of other junk. Ive got a stock 6cyl, 31inch tires, T176, and the stock 2.72s in the axles. I had gone over the brakes with a fine tooth comb before we left, (along with everything else). Managed to make 70-75 mph indicated, and still got 14mpg on the flat highways (Ohio was all uphill, and PA was nothing but mountains-suffered a little there) I hit the scales in Texas with just the uhaul and hit them again in PA fully Loaded (The Army paid by weight, and you had to have your empty/full weights measured at opposite points) Turned out I was pulling a little over a full ton. 2,200 pounds or something. Not bad for the lousy gear ratio. The sales literature for the Unlimited lists max trailer wt as 3500 lbs, with 300 lbs tongue weight. and GCVW as 7800lbs, if that gets you in the ballpark.
