Toys In Hummerland
mulescj8
INSANE SCRAMBLER HACK
Middle of No Where and Too Far From Any Where
Tn
Saturday morning we met with 12 rigs we decided to split into two groups,we had 8 toyota landcruisers,7 FJ40s and 1 FJ55,the rest were jeeps,the group that i rode with were all "TOYS" and 1/4 mile into the first trail "our" leader lost a front shackle and punched a hole in his oil filter,a quick run to town and a new oil filter and a new bolt in the shackle we were moving again,most of the group was very nervous with reasons to be since this was their first time out on these trails.The trail that we were running is called "Ryans Rock",it's appox 1 1/2 miles long of huge bolders and rock slaps.An hour and half later we made it to Ryans Rock,this rock is usally wet and it is at an angle where you can not get a straight shot at it,to make matters worse it has a two foot ledge that is under cut and usally has about an 1" of water running across it,This day it was dry and it only took 30mins to get all 6 rigs over it.
We then ran on up the trail on a dirt road that travels appox 1/2 mile before droping back into the rocks,we traveled up another 1/2 mile of boulders into the SHUTE,this place you have to make a hard off camber left turn to a turn around to get lined up for the shute,as it drops into the rocks there is another 18" ledge that you have to climb and as soon as your rear tires are on it you'd better be in the right gear and standing on the gas because the shute is a very steep loose,offcamber,rough hill appox 1/4 long you don't let off untill your at the top.The next thing we did was drive to the swimming hole and have lunch before taking on the "Dollys Squeeze"trail.After we broke from lunch we lined up for the run up to Dollys squeeze,the frist one up has to have a working cb to let everyone eles know when to take their turn.The climb up is steep steep! Very loose and offcamber with a couple of twist in it to complicate matters,the first is a huge slap of rock that sticks out that every wants to try climb over just as your motor is starting to pick up some speed,it then will toss you to the right at speed to the berm in the edge with a two hundred foot drop to creek,this will always pucker your passengers up! If you don't make it over this part it's a long ways to back down a loose off camber trail to get another run at it,after making it past that there is another 12" offcamber loose ledge that you have to power over and once over that it will put you offcamber and almost sideways to continue the climb on up which is pretty easy from there,if you make it that far,the trail then clims a short distance to the Squeeze,this is a huge rock wall that is several hundred feet high and hangs out over the trail,no fullsize trucks here! They won't even run the Hummers on this trail! When you get to the squeeze it makes a real hard right that you have to make a 4 or 5 point turn into to get lined up.Then you have to start to the far right and bounce the right front tire up onto a 2 foot ledge and then stand on the gas as it throws you to left really hard and brings your rear around to the right just as hard,after your fronts get up and over you will then be dumped back to the left towards a big drop off in between two rocks if you let off and roll back you will find your rig laying over to its left in the hole with the body resting on the other rock,if you make it up,man what a "FEELING",if you don't your still smiling when you say pull the winch!This part of the trail is usally very wet to add to your excitement,but was pretty dry today,This was the first time that i had ever made it up without pulling the winch which all but one other did!This was my fouth try at the squeeze!We then went and run the rock garden which is a play ground for the rock crawlers,huge and i mean hugh rocks to climb and play on,we only broke two rigs so it was an end to a great day! The other group that had split off had two rigs broke and a roll over,so they too had a great day!
Sunday we road a eaiser trail called the "Deep Down Mine",i say easier it's still a high callenge trail with a ton of rock climbing and off camber places,it takes about three to four hours to run with 6 rigs if no one breaks down,we got lucky and no one broke,from there we went back to the "Rock Garden" and played untill the FJ55 blew the high preassue hose off his power steering,after making some trail repairs we all decided to get out while we could and go get cleaned up,we met later that night and ate lots of mexican food and told our "war stories":D
One or two notes we have lots off pics which i will post some of them when i recieve them from everyone and i had a newbie with me on Saturdays ride and he fell in love with our "sport" so he got a new passion to finish his "TOY TRUCK" that he has put off in finishing.:D And i want to say thanks to the NORTH CAROLINA LANDCRUISERS ASSOCIATION for traveling 400 miles to come to my back yard and play with me-thanks again guys and here is a few pics of them untill i can get the pics of my rig from them-JC
another pic
here's another one-JC:D
another pic
another one-JC:D
Here is one of my rig
here is one of mine while we were waiting on the group to get out of the Hole they were in,one of the guys has some awsome shots of my rig on the trail that i will post as soon as i get them from him-he is going to burn a disk and send it to me so stay tuned for more!-JC:D
heres the last one for now
had to include the FJ55 this thing is a beast!-JC:D
Mules, nice pics. I hope you showed those "Toys" how to wheel. The truck looks like it is holding up good for you since the rebuild. Have you found any pros or cons that you would change yet?
Can't wait to see the rest of the pics.
everything has worked good except for a promblem with the TBI dying once in a while at idle,which i think i need to set the idle up a little-JC:D-One of the Toyota guys said "The trails here make Tellico look like a paved road":D
Thanks for the report,and pictures, sounds like it was a blast.
As i looked at your Scrambler again, i keep thinking about doing a "red version" of your paint job on my Jeep. I don't think it would look near as good as yours does but at least it would stand out!
CLOSE YOUR EYES AND IT WON'T HURT FOR LONG
Go for it i think it would look so cool,it will get alot easier after you put the first "spot of paint" down-JC:rolleyes:
more pics
here's another one
yep another
more pics
only two more!
this is the next to the last one!:D
here is the last one
saved the best for last-:D
Thanks for sharing the pics!! Looks like you had a great time and your 8 looks awesome!
my pleasure
Glad to share them with everyone and it was a ball,if all the trails were like these and i could ride them every weekend i'd be in heaven on earth!-JC:D
