Trader
John
Yes, its true, I threw in the towel. I gave my belovid 63 8 to my nephew in az. It needed too much attention for me to handle. the good news he promissed a full restoration. I have since bought 2001 Ford Ranger 4x4 [ not as much fun as the 8 ] any way I have a question for you guys, When I got the truck the front tires had wear on the out sides and it pulled slightly to the left. I took it to the shop and was told it could not be adjusted for chamber caster without putting in an adjusting kit. After installing the kit and adjg. to fact.specs. it continued to drift left.I was planning to change the tires in the spring to see if that would make a differance. However after 3 weeks of pulling left it just started pulling right. Is it the Jeep Gods playing tricks with me ? any input would be appreciated Thanks John
JEEP GODS
Yep the Jeep Gods have sent you to Hell or in this case sentenced you to the Ferd Ranger for you devious deeds!-JC;)
I had an 88 Ranger, same problems.
I took it to the dealer they said it was "within specs" even though I could see that the tire was tilted in at the top.
Lame.
I never fixed the problem.
Sold the Ranger, bought my Scrambler
I took my wife's GMC van in for an alignment because it was pulling HARD right. The shop told me it was within specs and didn't need an alignment. They suggested rotating the tires and, believe it or not, problem solved. So maybe you could try that.
Also, I have a Ford F-150 so here's a site that I have found to be very good for info on Ford trucks:
http://www.ford-trucks.com/forums/
Good luck! And sorry to hear about your Scrambler. Tell your nephew about this site!:)
-Mike W
Don't get an alignment with worn tires as they will skew the numbers slightly. Best time to get an alignment is when you get the new tires put on.
Also, worn tires themself will pull.
John - sorry, I didn't think about this. My wife's tires were not worn at all, so that's probably why they suggested the rotation.
-MIke W
trader
Thanks for your input, I may not have the Scrambler any more but I still have this great site. You would not believe the crap I logged on to in a Ranger site. Thanks again, and thanks for that ford truck site.
Re: trader
I bet I can...
Eric (<--- ex Ford Contour SVT owner and Contour.org site regular)
