Trailer Brakes
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
I have a Flat Tadem axle car hauler I want to put brakes on. Does anyone know how hard this is? Do I need them on both axels or just one? I guess in the case electric brakes are the way to go. Is there a kit out there with everything in it to get the job done?
Stouttrout, I am getting ready to add brakes to my twin axle trailer. My local guy that sells trailers and has a junkyard told me that rear axle brakes would be sufficient. All my parts arrived the other day, haven't installed yet. Your trailer axle must have a square flange on each end with 4 wholes to mount the new hub brake assembly to.
You can buy the whole hub and electric brake assembly for each side (they are left and right) plus the control unit for your tow rig. Everything I got is made by Redline (I can get you the part numbers later if you like). I think you have to use existing bearings with the new hubs. You will also need to know the bolt pattern of your existing wheels when ordering.
My local trailer guy orders my stuff for me ($267) but I am sure you can find it all online or somewhere local. I will need to purchase some wire and a 6 wire round plug and adapter to fit my 1500HD and that should be it for supplies. I just need to find time to get it done. I will post when finished.
Dan,
Call Husky Trailer here in Houston. They carry everything you'll need to make the conversion. As Chief said, all you need is to do one axle. Electric brakes are the easiest way to go. Surge brakes and the like require alot of extra work, and modification to the trailer. It sould be pretty much a bolt on deal...
While you can get by with brakes on one axle, I would strongly recommend brakes on both axles. If you ever need to do a panic stop, you will be glad to have all of the braking power you can get.
You should be able to buy the backing plate, brakes mechanism, and new drums for under $150/axle. You can buy a whole new axle with brakes for $200.
One place to check is Northern Tools, or do a search for "trailer axle parts". You will need to know either the size and manufacturer or the spindle dimension to get the proper hub assemblies.
Hmmmmmm........ Is there another way to stop? :D
Stouttrout said:
kohldad said:
If you ever need to do a panic stop, you will be glad to have all of the braking power you can get.QUOTE]
Hey Fernando and Mike......care to discuss "PANIC STOPS"??? :eek: :eek:
for trailer brakes and supplies contact www.redneck-trailer.com
or for the best braking system ever contact www.towbrake.com
do yourself a favor and put brakes at all four wheels you'll be glad you did the first time you have to make a panic stop!
Brakes on both axles are also required in some states like PA. Been seriously thinking about adding brakes to my other axle.
Where you getting those prices and what size axle they for?
Just do some searching. There is a better place than this, just don't have the link handy. But a quick check found http://www.lowcosttrailersupplies.com
5-bolt drum assemblies $42 each
Dexter brake assembly including backing plate $40 each
Total for axle is $164 + shipping
Or you can try http://www.etrailer.com
5-bolt drum assemblies $50each
brake assembly including backing plate $45 each
Total for axle is $190 + shipping
Cost for the brake assemblies for 3,500# axles and parts are just over the $150 I mentioned, sorry.
However, the trailer axles complete were found at http://abctrailerparts.com/axles.html where you can purchase a 3,500# axle for $191 complete w/o springs or $214 complete w/springs.
Hope this helps.
