Ok John i know what your thinkin'..........why the hell is mule even replying to this he ain't even got a whole Jeep......lol...............I have a 18' and i'll tell you a few things to look at and try........1st you are using "trailer tires" right?
the belts in them are differant than car or truck tires..........using car or truck tires on a trailer can cause ill handling..........Ok you have trailer tires,good......on to the next thing..........put a tool box on the tounge,one of those made for the tounge will work just fine.......or even better build one out of 1/8" to 3/16" plate steel..........put lots of tools and spare parts in it that should add close to 200 lbs to 300lbs or more to the tounge..........mount your spares(2) on the very front of the trailer also this will add another 80lbs or so.I have even seen(not implying that you have done this) put the load too far forward and basicaly unload the rear trailer axle and putting the load on the front trailer axle and the rear axle of the truck.................One other thing. Have you change your truck tires?.....I did on mine and it was a nightmare to hold in the road untill i put about 10,000 miles on them................JC
