Truck's project begins...
Well, Truck, I have not made any more progress than you lately. In fact, since last fall, I have had more tubes and screws put into me than have been installed on my cj8 project!
Since I am supposed to take it easy for the next couple of months because of my sugery last fall, I went ahead and had my torn rotator cuff (old football injury) repaired last week. Had about a 75% tear in a tendon along the cuff. Took three permanent screws into my shoulder and now I'll have a sling for a while and physical therapy and then limited action for a while.
But the good news is that by mid to late summer, I should be in much better shape than I was a year ago! Hope I will be able to say the same for my cj8 project then, and yours as well!
Later
-Mike
Thanks Eric for poking me in the eye.
Thanks Mark for the offer, you have no idea how bad I wish I could bring it and everything else I own to Colorado, but for now the military still owns me.
It is next on the list. Between the tow rig needing a new engine, work on the house and property, keeping the current trail pig held together for the little wheeling I do, and trying work hard enough for extra coin on the shop, it has slipped down the list. However, the biggest phase of the shop got done this year. Felled about 30 trees, moved my fence, excavated and got the plumbing run, finally the slab poured, with some final grading. This doesn't include all time and BS spent with the county on permits and inspections. Now to just sell more stuff or wait on saving enough to get the structure erected. I'm hoping to have it done by the end of winter. Then Scrambler build will restart.
Truck
Truck
Sorry, I was just thinking of a couple builds yesterday and was curious. But this is what I was hoping to hear, progress!
I'm jealous of the progress on the shop. We got this place partly because it has space to put a shop, but it's probably years off. Sounds like you did all the really hard stuff already. You building it yourself with subcontractors?
I wish I was close enough to make the first wrench-fest in the new shop :shrug: :banghead:
I cut the trees down my self with help from buddies. I did some of the plumbing work. I hired a contractor to do the excavation and slab. It wasn't a simple 4" pad. It had to have 14" wide footers that were 24" deep. I also had to make sure there was a little extra concrete under where the lift is going to go. If ya'll want I can post up a build thread with tons of pics.
Truck
:thumbsup:
We need a garage/shop forum on here I think... regardless I love seeing ideas for shops!
am i crazy
i pulled my tub myself, just bought 2 of those 4 wheel furniture doolies at home diptoe and padded them up slid the tub off the side onto the dollies is that so wrong, i actually have done all my wrk on the tub on its side(sanding grinding por 15 wrk and undercoating and bedlining) friend of mine is designing a frame stand that will hold the frame and body or the frame or body and itll rotisserie on bearings its gonna be uniersal for cjs and pretty cheap to but built havy duty with industrial bearings
