Truck's tow rig kewl toys
Truck
Manassas
Va
Okay this is for BurntOrange and a couple of others that have asked questions and pix of this set up.
The generator is actually I believe an alternator. It puts out 12KW and 15KVA. The power panel has 110 and both single & 3 phase 208. The air compressor is hard wired into the power panel and is 3 phase 208 (can you say air tools, oh yeah) In the cab is a pullout PTO control with a governor switch that regulates the engine rpm based on power draw (I think).
Anyway here are the pix. If you have any other questions ask.
If anybody has more info on this stuff please pipe up!
For those of you inclined in the electric department (Carl) what do you think it would take to make an ARC welder attachment?
Truck
Alternator
attachment.php
Alternator spec plate
attachment.php
Power panel
attachment.php
Air Compressor
attachment.php
Some more pix
Here is the PTO off the 205 tcase
attachment.php
Belt to turn Altenator (I don't know where to even start to find another one of these)
attachment.php
PTO pullout control in cab
attachment.php
PTO governor switch and PTO indicator light in cab
attachment.php
PTO governor on the front of the engine
attachment.php
Generator, alternator... who cares?????
Can you say mini-fridge, big screen and satellite?!?!?!?
I'm camping next to you at every event!!!
That is so sweet I don't even know what to say!
It seems like the compressor could be mounted differently to leave you more space in the back for storage though. If you could get it all mounted up at the front above the alternator you'd be SET UP! Maybe remove the storage tank from the unit and position it under the bed somewhere? Pipe it all up and go to town!
I think all you need for a welder is the control/plug panel you have the juice covered in spades. Hook it into the appropriate circut and start burning metal!!!
Yep I've been thinking about this..my big limfac on this vehicle is seating capacity. I'm toying with the idea of boxing off the area behind the altenator, putting a cover on it, and mounting those bucket seats facing the rear. Then maybe cut out the rear window hole in the box, take the cab window out and put a boot between. Then with a bench in the front that would give me seating for 5. All that said, I would have to put the compressor in one of the side cabinets. The tank is long and skinny enough to go under the box somewhere and they are already seperate units. Then an air mattress in the back and should be good to go. None of this will be done anytime soon as the Jeep has priority!
I wish I could afford to buy this and then just mount all my heavy duty stuff and box on it. I've been watching it. But I think my wife would kill me or leave me. Either way I prefer the status quo. :D
Truck
Thanks for the pics Truck. Your new rolling utility substation looks great!
I think your NP205 PTO used a Gilmer style cogged belt to drive your generator. These were used more widely before poly V belts became popular. What's the width of your belt? If you start searching I don't think you'll have too many problems coming up with a source for a few spares. Here's a place: http://www.jonesracingproducts.com/blt/sqr.html
Next time you're underneath try to grab the Chelsea part # from the PTO housing.
Looks like the easiest thing for welding would be to find a used Lincon AC/DC buzz box and then just plug it inot the power panel at will. That way you can weld from your house and from the truck whenever it is needed. You shoudl be able to find one used for arround $100. Rember the one that I picked up in Atlanta. I would say something like that.
They are not the easiest to use but if you are good at stick welding then you would have lots of power. Also if you found a good deal on a mig you could just use that too.
Either way it is probably easier than trying to wire something straight into that panel.
Carl
That's one sweet set up! You'll be everyone's buddy on trail rides! :)
Looks to me like you could run any welder with the panel you have there. All you need is 240v single phase. That should be that big rectangle plug in the center. Like CBRogers said, just plug your cracker box in and start running some bead... :)
Looks good...
Thanks Burnt,
I have them. I have everything the guy on ebay sells on his CD plus a few more. I downloaded them from work as they were still active pubs on the military side.
If you see something though don't hesitate to pass it on as it is better to have 2 then 0. Like the 12V conversion piece you sent, I didn't have it or the other pub.
Cheers,
Truck
Now Eric spoke up first so he has dibs on being my friend..but I guess I can share my friendship just a little. :D :eek: :p ;)
I will probably get a Mig at some point and use it plugged into the power panel. I didn't know if an ARC welder could be wired up easily with just the cables..don't know enough about it..and this would be immediate and cheap!
Maybe I will get a cheap small Mig for now so it will fit in the truck easily and get a big nice one for my eventual shop later. Most of us shouldn't be doing too heavy of repair work on the trail anyway. If I went this way, anybody recommend one of the cheap ones over another in $100 - $200 range. I can't afford a Miller or Hobart right now.
Truck
My primary welder is a Miller 130 I've been using the hell out of it for 7+ years with no problems but it was expensive. There are some 130v MIGs that are a lot less expensive, but I don't know anything about them. They ought to be able to weld 3/16" without trouble which will be more than adequate for trail repairs. which ever one you get, I'd spring for the CO2/Argon bottle....I never could get a good weld using that flux core wire...I just use my old lincoln stick welder for heavy stuff....What ever you run, you look to have more than enough amperage to run it.
WOOHOO!!! *Eric sticks his thumbs in his ears and waves his fingers like a 4 year old* Neeeener, neeeeeeeener, neeeeeeener! :D
Who am I kidding, Truck has the juice for a whole boatload of friends! :D
