TRXUS MT Tires????
Just wondering if anyone is running these tires, or has had experience with them:shrug:
http://www.intercotire.com/tires.php?id=11&g=1
The 34x12.50x15 size might be the cure to my rear rubbing issues:thumbsup:
I have had Super Swampers before, both radial and bias, so I know the on road ride will probably not be as smooth as my BFG KM2's, but all that siping on the tread blocks should really help these tires hook up on rocks:D
So has anyone here run these tires, or know of someone who does:shrug::thumbsup:
I did and loved them. They were surprisingly quiet and smooth on road and did great off road. I only got rid of them because I found a great trade with a guy who was looking to drop down to 33s when I wanted 35s. The only thing I could say at all bad was that they chunked up a bit, but nothing that ever worried me. I'd run them again with no hesitation.
x2.
Sam had them in 33x12.5 on his Scram. They are siped and do well on the street, as well as well off road.
I have no personal experience with them however a good friend of mine runs them on his CJ-7 and I would say he would echo the above comments.
Forgot to mention, though probably not an issue for you in MS unless you take a road trip, but for anyone else that sees snow... these were a massive improvement over the blocky MTs I replaced when it came to snow. The siping really did pretty great.
Interesting, I have not seen these before. Be sure to post pics if you end installing a set. This could be my answer to my 33-35 dilemma! :fingerscrossed:
What gear sets would you run??? :shrug:
I ran a summer with a guy who had these in a 35" on an XJ. They were awesome, and may still be one of my tire choices if I ever get enough money saved up to buy tires.
I run a set of Trxus 31 X10.5 X 15 on my 91 YJ and they work fantastic. I was very surprised how quiet they are on the road. For a chucky as the tread looks, I have had several sets of BFG tires & these are quieter. Also echo the good (G R E A T ) performance in the snow. Probably would work decent in mud too cause the tread comes around the sidewall a good way & gets nice bite in the slop. I bought these & rims in a pile of parts from a guy. I sold of enough so the set with rims cost me around $25 + mount & balancing. THEY ARE HEAVY!. I ran them first on my 2004 TJ but kept them for my son's YJ (my former one before I bought my 85 Scrambler) cause they are such awesome tires. They also look real mean!
I include pics of the BFG AAll Terrains the TJ had originally ands hten with the Intercos. The Generals that were on the YJ sitting in the snow in front yard were what I sold the TJ with. This pic is not too long after we finished the frame off with parts from Colorado. The Generals were decent tires too. I have had 3 sets of BFG All Terrains & was not happy with any of the 3 sets. In fairness, they were all used when I got them but every set had a problem with one or two tires. :evil:
Hope the diatrib helps- the short version is I would not hesitate & even would prefer the Interco tires! :smokin:
Excellent replies:cheers:
This looks like it might be my new tires. I am hoping the slightly shorter stature (34" vs my current 35" BFG's) and the slightly narrower tread width (app 9.6" vs roughly 11" on my BFG's) will clear the rear sheet metal. The only place I rub is directly behind the rear wheel opening. When the suspension is fully compressed, and the tire angles up and inward, the sidewall/very edge of the tread catches the lip of the fender flare, then hits the metal. Hopefully, these being slightly narrower and shorter, will clear:fingerscrossed::fingerscrossed:
I really like the slightly added height of the over 33" tires. I was happy with 33" tires on my CJ-7, but the longer belly and rear overhang of the CJ-8 is what interested me in slightly larger tires. I still need to a little bit more research before I pull the trigger:thumbsup:
I have 4.10 axle gears. With the T176 4 speed and 35" BFG's, i was running 2800-2900 RPM at 70 MPH. I am swapping in a T5, overdrive, to help drop the highway RPM:cheers:
I have MPI on my 4.2, and it has great power pushing the 35" tires with 4.10 gears. If I lived in the mountains, I probably would have went with 4.56 gears. But, it is relatively flat down here:cheers:
Thanks for the info:cheers:
My tire guy echoed your same sentiment, these tire are heavy:( I need to compare the weight of these vs the 35" BFG's:shrug:
EDIT - Just looked up the weight difference. The 34" Interco's weigh in at 64 pounds, the 35" BFG's weigh in at 59.94 pounds. Since this isn't a sports car, I can't see how the 4 pounds heavier weight per tire will really hurt?
the 4 lb difference is nuttin'! Another thng to consider. My son who has always thought in numbers measured several sets of tires I have had as well as some of my friends Jeep tires. A firend where I am doing the tub work on the Resurrection Scrambler build has a CJ-7 with 32 X 11.5 X 15. It is a great looking Jeep. But the 32s measure actual closer to just under 31 inches. My old set of 31 X 10.5 X 15 Generals in the picture on the black YJ measured just over 30 inches (still had decent tread around 13/32 deep). The Interco Trxus on the other hand the 31s measured a full true 31 inches. I am not sure how closer other tires match but an interesting observation. :cheers:
Yep, certain tire brands run closer to their advertised heights. Some of that depends on rim width, too. I had some 33x12.50x15 radial TSLs, mounted on 10" rims. Brand new they only measured 31.5" tall. I also had bias 33x12.50 TSLs mounted on 8" rims, they measured a hair over 33" tall. My buddy, who has my old CJ7, has 33" MTZ's mounted on 10" rims, 31.5" tall. I forget what my 35" KM2s measure on 8" rims? The 34x12.50x15 Trxus MTs supposedly measure 33.6x9.2 once mounted, which should be what I need:crazy:
Waiting for a local guy to measure one of his 34x12.50x15 TRXUS MTs, mounted on an 8" rim. I want to see what the actual mounted size is before I purchase new tires.
My current 35x12.50x15 BFG KM2 Mud Terrains measure 34x11.50, mounted on an 8" rim.
As long as the TRXUS are narrower, hopefully a little less then 10" when mounted, I will get these tires. The advertised mounted size is 34" tall by 9.6" wide, so :fingerscrossed::fingerscrossed:
My buddy that has the 34x12.50x15 TRXUS MT told me his mounted dimensions are:
33 5/8" Tall
10" wide at the contact surface, 12" at the widest part of the sidewall
That is with 30psi, mounted on an 8" rim.
That might still be too big:(
His 34x10.50x15 LTBs measure:
33 3/4" Tall
9.5" contact patch
These might be a better choice, but they are Bias Ply. Not sure i want to drive from Biloxi, MS, to Moab, Utah, on Bias tires:(
Might have to go to 33's, or i might just give the radial Trxus a shot, and adjust the rear bump stops if necessary:shrug:
I think that if i want to keep my factory 8" rims, I am going to have to go back to a 10.50" wide tire. My 12.50" rub on the leaf springs up front and I can not get full turn. I don't want a 10" rim, but if I want to stay with a 12.50" tire, I am going to need new 8" rims with less backspacing:(
Has anybody else ran into 12.50's on factory 8" rims rubbing the leaf springs:shrug::shrug:
I m currently considering going to 33x10.50 KM2's on my factory steel wheels, or 33x12.50 KM2's on aftermarket 8" aluminum rims that have less back spacing, to help push the tire out slightly from the leaf springs, but not as much as the 10" rims:shrug:
Any thoughts or opinions:shrug:
Will the 10.50 give less stability on extreme side hills???
Maybe 33" tires on the factory 8" wheels wont rub due to the slightly smaller OD compared to the 35's???? I know that the 32x11.50's mounted on factory 7" rims cleared everything fine, with no lift:shrug:
I know my 33x12.50 BFG AT's on factory 7" rims do not rub at full lock. That being said, the tires were not new when I put them on, they had around 3/4 tread. Second, the lift was a Rough Country with the narrow CJ leaf springs, not the wider ones like the RE lift has. Third, I assume the OEM 7" rims have the same backspacing as the OEM 8" rims but I do not know that for a fact. Not sure if that helps or not.
It is some more info to think about:cheers:
I wonder if my slightly wider "YJ" width front leaf springs are causing the rubbing? I find that hard to believe, though, considering the springs are only 1/2" wider total, 1/4" wider to the outside.
Maybe it is just the larger OD of the 35's, which cause the edge of the tire to be farther from the pivot point of the knuckle, which is the problem?
I will have to compare the back spacing between the 7" and 8" factory rims:thumbsup:
