Wagon Wheels
I never re-cleared mine and I've not had any issues with rust. Of course they didn't have any rust to start with and I keep them clean. I have heard that for a correct OEM look they need to be re-cleared so they aren't too shiny.
I was under the impression that with a round base vs. a cut out base on the hub, you couldn't get the center cap over it.
So, when you say you cut the end out, yours was able to pass through?
I agree spacers would probably work, how big did you get, just the thickness of the hub base?
Also, does it stick too far out now past the rim/tire line that it might get snagged on something?
Craig
Since this thread is kind of taking a turn in that direction, I have a question -
I have a rear wheel-cover that is loose and 'clicking' or knocking at low speed. It might be doing the same at high speed but I can't hear it.
Is there a straightforward way for tightening these?
This is probably the best pic I currently have that shows the offending cover -
That would be what I would do... and if it is tight, then you know something else is making the noise, like perhaps the 2 piece axles?
It may also be as simple as a rock in your brake drum. Or worn rear brake parts :eek:
Thanks guys... I am going to try and get it squared away this coming weekend.
Craig
Looks like you could BARELY grind a little relief in that hub housing and it would work. That a standard 5 bolt warn hub?
Yes, that is a WARN 5 bolt hub on the right and the standard OEM one on the left, and yes you could get away with probably grinding it down 1/2" or so to clearance it.
As for the "older" hubs, which in re-reading the article, might be 6 bolt hubs, I don't believe t here is a chance, as you would need to clearance the bottom as well as the top I think to get over them.
Sorry:edit
I found a picture of the 6 bolt hub I have swapped onto my 82 wide tracks...
This is what I was referring to... round base would not fit over and the top might be too long.
I run Dana 44 Warn Premium hubs on mine, the center caps clear fine, front and back:thumbsup:
Swap to "internal mount" hubs, kill two birds with one stone:
1) eliminate the failure prone bolt on hubs
2) factory center caps clear with no issues
:twocents::thumbsup::wave:
I think he meant internal vs. external
I have the external versions of them, they won't clear.
How did you get the rear full float kit to clear the cap? I installed the same thing on mine and no dice.... coupled with an external hub on the fornt axle and I am now going "capless".....
I used a "front", "open ended cap", on the rear. I did not have to modify anything, it slid over the Warn components just fine.
I used the same open front cap and it would not fit over the Warn hub flange, it was too wide. I will take pictures tonight when I get home and post it up. Who knows...:shrug:
Are you running the factory wheels/offset:shrug:
OK, so now I feel stupid.... not sure what happened before but now it works...
Warn full-float hub
Final Install
Mile Marker hubs on front axle
No cut outs, cap won't fit...
